yes it is imprortant to know that the drop is only allowed with appliances included in TT, if you isolate appliances and test carcass and there is a drop that is a big NO NO
i am of course teasing,no offence meant just have a GSOH
Sound like the sort of tossers I used to see in Plumb Centers all the time before I stopped using em; Snickers work trousers (Regulation bright blue), Walk straight round counter like they own the place and get their gear from the back themselves, rest beer gut on counter while drinking free coffee and telling everyone that will listen that "They're pulled out with work, aint had a day off since 1976, fitted 2 full systems since 8 this morning and still got another 3 to fit before 4 o clock & I don't need to do a tightness test cos I'm the bestest fastest gas fitter in (Insert the town/city of your choice)!" I always do a test before and after every job cos to be honest, I'm just too pretty to go to prison😎
These sort of blokes can make you doubt yourself and love to think they look big in the merchants. Rant over!!😡
Second post in as many days.
Just been in plumb centre and was earwigging on two guys talking about testing.
Now I'm a commercial fitter with domestic as well. Granted I have not used my domestic that much over the years but it does get used.
Now the way I was taught was the following;
Upon entering a building to do gas work you do the following:
1 minute let-by at 10mbar
1 minute stabilisation at 20mbar keeping at 20 for that minute
2 minutes at 20mbar.
Anything above 75mbar is medium pressure and requires a different test (this was where I got into conversation with them as they said anything over 82.5 was medium)
Any Drops at stabilisation are fine, any drops within 2 minute test need to be within permitted limit otherwise test fail and you need to find the source
You then do any work IE boiler service, then after the work do the same again.
Now these two guys argued with me for five minutes that you do only need to do a 2 minute test at 20mbar.
Any drop is fine as long as there is no smell of gas.
Also that doing a test upon entry is not needed, and I was wasting my time.
Now somebody please tell me I'm right, I don't have my domestic viper with Me so cannot check, but I will be mortified if I have been doing it wrong all these years!
Honestly these lads have put complete doubt in my mind now, to the point that I'm worried about doing a test today!
Now I am not gas safe registered yet, but isnt it obvious, if there is a drop, there is a leak, which means that there is gas leaking into a house, which means that the installation is dangerous, I also got told by college that the first test must be done as if it is leaking then you must cut the gas off and declare it as unsafe, if the customer does not let you fix it, then you must report it to the gas board, I believe.
And common sense is that if you don't do the test first, then when you work on it, you may cause the already leaking pipe to get worse and of course, the customer will always blame you.
"it was working before you came"
As many will know, its quite possible to have no perceptible drop but still have a smellable leak.
Equally, in the right circ you could have a drop or a rise which isnt attributable to leakage/let by.
You can have fluctuations with the pipework temperature, but in rare circumstances you could have let by from the ecv and a leak at the same rate, so it shows no drop but there is a leak, in two places. You would be unlucky to get that. But if in doubt, unscrew the governor and spray leak detector into the closed ecv.
Threads 4 years old hope they'd have worked it out by nowgenerally a tightness test is carried out , if it is a new supply,or the supply has been turned off, if you are going to work on the actual installation or add appliances, or the customer suspects a gas leak (smell of gas). You dont have to do a tightness test if you are servicing an appliance ,unless your company wants you to do one, as you can isolate at the isolating valve test disturbed joints with LDF. Contrary to a previous reply, a tightness test includes a let by test for 1 minute at 7-10mb, a temperature stabilisation for 1 minute at 20-21mb, and a tightness for 2 minutes at 20-21mb / this is for a low pressure installation. Its never been acceptable for a stabilisation test to be done with the let by test (thats for bartdude pubmember attention)
