kinked, crimped and coiled 8mm pipework
View the thread, titled "kinked, crimped and coiled 8mm pipework" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Sorry, I've only just seen the posts above.
I have to admit Shaun, you've hit the nail on the head. I love nothing more than doing the work myself and seeing the end result - plus 9/10 it means i can understand how something works and address any further issues that I find - I have a good engineering (albeit not fully qualified in any one field) background which seems to get me out of most situations, although I refuse to touch plastering (don't have the patience), roofwork (can't do heights) and obviously gas work....
JTS - I think the view on giving advice for free is different for many people/trades - My thinking here is that I am doing part of the 2nd biggest job that my plumber would do beyond the boiler/cylinder, therefore I think there's a point where I could be being too cheeky. This is partially why I've taken the initiative to come on here first - If I can't get the answers I need I'll have to approach my plumber, but I'd rather not bother him until I'm closer to doing the job for integrity reasons.
The other reason is as Shaun says 'funds' given my wedding situation... although I can't say I'd necessarily do this job any differently other than to have the unvented fitted now if I was able to afford.
Cant understand why your plumber would not want to call in for a quick chat, if you have as you say used him for years , I have been in this game for more years than I like to remember, covering most size jobs, from area installation manager to running my own company, and it only takes a little time or phone call to ask how things are progressing, a lot of builders I know do own plumbing as well as DIY home owners, and I get asked to do parts of job that they cant, but I always do the odd site visit or phone them to see how things are going and if they need any advise, never found it to be a good idea to just let people rush ahead no mater how competent they think they are, But its your choice on how you do things, just not how I would do it,
I can appreciate what you are saying and can relate to a lot of it through my work. I just think, the last time this chap did some heavy work for me was my combi several years ago. I've gotten him full central heating jobs since with relatives but I think I'm pretty small fry compared to a buy to let or house builder - so prefer only to contact him if I need to.
I only really have one question though, about the possible requirement to have a certain distance to the first rad T off. The rest of the conversation was had with my plumber when he visited agreeing for me to change the feed return pipes and installing the extra hot shower feed from the new site 🙂
I'm guessing it's a silly question asking about any minimum distance to the first rad 🙂
Another quandary. After pulling more boards I can see the 22mm pipes terminate at various places with a 4 head 8mm pipe manifold cap, soldered onto the 22mm. Now I can remove this and add another manifold at great cost, or but a reducer on the end to 15mm then branch off several 15mm T's. Which is the most accepted way to do this by the professionals?
T off the 22mm in 15 mm and run a set for each rad (within reason you can t off 15 but you have to watch your rad sizes two 1200 x 600 are fine)
The worst case I have is 4 rads off one 22mm branch, medium sized k1's. And one 800x400 towel rad.
Would I be good reducing to 15mm with a straight push fit, then a series of 3 15mm T's immediately after to save cost. Or would you recommend a series of 22mm reducing T's in line
Edit: I'll try and upload my drawings of the upstairs pipe run later, to give bit more perspective
22mm ts
Cheers Shaun, much appreciated :coffee:
I gather it won't make much difference to the flow if I use the end of the last T for the fourth feed, or should I cap this
What could be of use to you and would answer a lot of your questions, Go on to CORGI web site . & purchase a copy of ( Wet Central Heating System Design Guide.)
Thanks for the suggestion JTS, isn't that a bit overkill though given the fact that I'm making some minor adjustments to an already installed system and asking some relatively basic questions.
I thought I'd use a forum to gain a bit of advice which is what it's here for is it not?
No it has some good illustrations and is easy to understand, even covers unvented systems just thought it may help you understand how different systems work, Think it gets handed out to guys doing plumbing & Heating course. used to get a heat loss CD so that you can work out rad sizes.
Extremely useful read... Thanks chaps. I have done a bit of independent reading too on star systems and the benefits of single pipe loops, feed and return and microbore systems prior to settling on the unvented. My plumbers initial advice was a large combi, but the need for high pressure hot water to the en suite, maybe eventually the main bathroom and possibly a second en suite if I get around to building it - he agreed that the unvented was the way to go.
One thing that was a concern was the suggestion that a feed and return system can handle roughly up to 12 rads, where I have 13. This is why I'm thinking of extending the feed so that it can be accessed by the new boiler more directly, than having to access the feed through the old pipework, running 7 metres of 22mm before it gets to the feed pipe
I think I see what your saying about the new direct 22mm run instead of going to the old airing cupboard. As all the pumps and valves will be down in the garage I would of thought.
Can you upload a drawing just to double check we are on the same page.
Will do, I'm going to put it together again before posting, to give it some scale. Currently the pump and electric switch for the hot water/rads reside in the airing cupboard, but they will be in the garage with the new set up... The diagram will show everything 🙂
This is the best i could knock together, apologies for the messy writing. All rads are fed by the 8mm manifolds apart from the bedroom above where the boiler sits - these two rads have a 15mm run to the tail of the main rad feed - all pipes on this map are the 22mm main feed, 22mm rad feed, 22mm rad return and the hot water return from the cylinder coil which taps into the rad return.
The airing cupboard house the vent pipes, the pump and electronic valve.
I was proposing putting in place a 22mm pipe to meet the rad feed which stops at the top of the stairs - the new boiler/cylinder will be in the garage which is on the same wall as the current boiler. The main feed and hot water return can then be removed from the system once the new system is in.
Is there any reason why you cant reposition radiators ? the bottom 3 seem a long way from main pipe runs, new radiators don't have to be under windows,
They are pretty long runs. The main bedroom definitely can't be changed as the rad sits in a bay window , the rest of the walls are taken. Ironically this is the longest run at about 5 metres.
The two smaller bedrooms off the landing could be looked at, but the run is already in place and the only thing I'm saving is a few metres of pipe.
I was going to ask about the bedroom above the boiler, it has two rads connected via 15mm to the 22mm rad feed. Obviously if I extend the rad feed then these rads will have their pipework reduced. But I can't help but think that if I remove the furthest small rad it'll remove unnecessary pipes and joints... I'll measure the rooms/windows/rad sizes and post up if that would be useful as a gauge?
Are all these rads fed by 8mm pipe, maybe you could extend 22mm to rad in big bedroom then 15mm along into other 2 bedrooms keeping inline with rads if you don't want to re-site them
Yeah, they all 8mm bar the two in the end room. Because I'll be laying the pipe to that end room for a more direct boiler feed, then it would be very easy for my plumber to tie in the larger rad above the boiler, removing a good few metres of pipe as that rad would be on top of the new extended 22mm feed.
My only concern is the size of that room. It's 6.5x2.6 with a k1 600x1100 directly opposite the door, in the map it's slightly off as it would have obscured the boiler. It also has a k1 600x600 under the window
The window is only 1m square.... Double glazed
Usely find radiators under windows a waste of time, people tend to cover with curtains, can you not do away with this rad and upsize the other one
Yep definitely, that was going to be one of my questions eventually 🙂 what I might do is lengthen the 22mm feed, tapping into that with the enlarged rad, and then cap the 22 off where I know my plumber will be jointing above the new boiler. That way I can install it all now for minimal disruption when he comes.
What would you do re this rad in the large room? Change to K2 similar size?
Reply to the thread, titled "kinked, crimped and coiled 8mm pipework" which is posted in Boiler Advice Forum on Plumbers Forums.
1animal1,
1animal1,
