E
Erik
Hello, I've got a blocked sink. I've taken all the pipes immediately under the sink apart and removed any blockages there. Further down where the pipe goes down vertically before making a turn into the wall I've put drain cleaner in several times. This has helped a bit, but the water still doesn't go down. When I open up this vertical pipe (it's basically the top pip slotting into the bottom pipe, so it appears not a solid connection) and let air in the water does go down, but if it's a large amount I have to do this several times to clear the water completely. Water comes up into the sink when the washing machine or dishwasher drain water. Any advice?
Thanks very much.
Erik
Thanks very much.
Erik
