If you watch online videos,the company suggests that loctite 55 should be used alone without any additional substance.
That is my worry,can this product offer a viable and permanent solution ?
Didn't mean whether it was used with ptfe, was wandering what context it would be used in.
Really like the couple of different types of loctite I've used for various things on the bike and and on the Bedford, looks like found new use for it then!
Use it and the tape for different applications, used the liquid 577 then known simply as threadlock on metal threads but the joints must be clean and oil free for it to cure.
Reactions: Pickwickpick
Always been straight ptfe but often wondered about the loctite. Any one say why it might be better than ptfe on some application ? Thanks. Wc1
I have found it to be more reliable than PTFE on radiator tails especially and also more reliable on fittings in the sizes above 3/4". I'm not sure why it works better but it does in my experience!
Great, I'll give it a go. If I'm gonna try something that could cause a leak in a customers house, I need to know why I should try it. Thanks 😀
I use Flomasta Pipe Thread Sealant from Screwfix on outside taps to wallplate elbow connections. It's the next best thing to welding it on, it's that strong. Using this on the threads eliminates the need to line up the wall plate elbow with the tap using a wrench as it can be turned to whatever angle you want and left for an hour to set. It won't move again and is fully watertight. When replacing outside taps, I usually replace the wall plate elbow as well so the fact that the tap can't be removed isn't a problem. To use it, I coat the threads of the tap with a zig zag line all the way round with the Flomasta and apply a ring inside the wall plate elbow. Screw both of them together to whatever angle you require, wipe off the excess and sit both on a kitchen towel for an hour. It won't come apart again.
  • Informative
Reactions: Wirdy and Stigster
After having used loctite 55 , I must report that this product gives the impression of a perfect sealing.
The tip is that you must cross - crossing the tape on the thread.
I ended up on the loctite 55 after having failures with the use of ptfe. Especially when I used ptfe on short adds on (photo below) or parts with short thread.
I noticed that loctite 55 offers a better solution .
Ain’t used PTFE for years - normally scratch up the thread a bit to give it a bit of adhesion, another vote for loctite 55!
What do you mean by scratch up? As in like keying in with some wire wool/wet&dry/emery or something else? Have never used loctite 55 but think will give it a try after all the recommendations in this thread.
See the vid in my earlier post, loctite recommend keying quality metal threads when using 55
First got loctite 55 for dual fuel t-piece / element, which have a nasty habit of ending up in the wrong orientation otherwise. Now I use it for all rad tails, outside tap, shower outlet... etc It’s much better than ptfe!
Cross cut a hatch pattern with a pair of grips or hacksaw blade
Got some 55 today, tiny little roll, I'll have to make sure I don't get it mixed up with my toothy floss!!
Also after spending decades generally preventing damage to threads, deliberately scratching up the thread is gonna take some getting used to. But overall looks good, thanks guys!!
Use miles and miles of the stuff, brilliant on threads up to 2"1/2 but got to be carefully any bigger then that as it can run up the thread even when you have scored them.
Reactions: WC1
Aaah.. is that what the thread scoring is all about? - stopping it running up?
If the thread is super smooth (well machined) I take an old screwdriver and drag it vertically down the thread to create a key for the loctite to grab to. In addition I apply from the start of the thread (ie the first thread to enter the fitting) towards the top, then back down to the start. This way the loctite is pretty sure to be dragged into the thread rather than pushed out when tightened. Love the stuff…don’t get me started on CT1
Loctite 55 is very good on rad tails, but I often do it with hemp and paste.
PTFE I keep for threads I don't want to seize up, and for wrapping 3/4" olives to allow connection to 1/2" alkathene. Wouldn't use PTFE to attempt to seal a thread out of choice.
M
7K
M
