C
coolaboola1234
Hi everyone
I built a new house last summer and since then i have had water problems. The pressure is fine and the tank is filling ok - i have monitored the tank during showers and baths and im confident that its not going down too low too quick
Here is my issue - a few times a week, almost every second day i notice the cold water start to run a little slower in the mixer tap in main bathroom, when i see this i check the cold water in the en suite pumped shower and its gone. If i dont do anything then this will spread to the upstairs toilets and sinks
How do i fix this ? I turn on the hot water in the mixer tap in main bathroom , cover spout with my palm and turn on cold for about 2 mins. This seems to fix the issue for a while before they come back again
I have also checked for air by letting water out from the valve in picture 1.I have also attached other pictures of the hot press , the main bathroom is at the left of the hot press and the en suite shower is behind it .
I have multple plumbers look at this and they do a few things and say "it wont happen again" only for it to reoccur in a few days
I would really appreciate any help
That's a lot of compression fittings in a small space for a new build.
Who designed the plumbing in the property, they should be sorting it out?
Or can I guess?
Who did the plumbing? There's not a soldered joint from what I'm seeing.
I agree that whoever did the plumb should be looking.
As a new build you must have guarantees?
Anything?
new last summer??
does the pump have a dedicated feed from the hot cylinder?
what size is the cold tank?
the pictures don't show enough.
pipe work most likely shaped like a dogs hind leg?
creating air locks, get it repiped properly.
no way is that on a new build i know they can be rough but whats on show has to look right complete bodge i can understand some sites have a no flame policy but the would use some sort of crimp system
Reactions: 2 people
Those shower pump flexi's are bent over at 90 degrees, only meant to provide a small amount of movement.
Its not a new build. Haven't been able to fit storage tanks to new build for about 15 years
Try to make sure the next multiple plumber is a real one.
Reactions: 3 people
