G
gastek
I saw a newly installed Ideal Ecomax system the other day with an Ideal Low loss header installed in the vertical axis and it all looked as expected except the flow was at the bottom and the return at the top. I could see that this was the easiest way to connect the flow and return from the boiler as it saved having to cross over the pipes. The system appeared to be working happily. Does anyone know if it is perfectly satisfactory to pipe it this way or is it just a general gravitational rule that by tradition we observe.
