Mira decor shower water running continuously from the shower head
View the thread, titled "Mira decor shower water running continuously from the shower head" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Hi All
Customers has an issue with a Mira Decor electric shower. The shower is leaking continuously from the shower head even when the power is switched off. It’s not a dribble but a flow of water. It was purchased in 2021.
I’ve isolated the water and electrical supplies and wondering if any one has a clue what the fault my be.
Many thanks
Sounds like a failed solenoid valve—common in electric showers, especially after a few years. If water’s flowing even when powered off, the valve likely isn’t shutting fully. Replacements are usually straightforward. If you're ever considering a stylish upgrade down the line, I’ve seen some well-designed, modern alternatives at goldbathroom.uk—worth keeping in mind.
Many thanks I will get one ordered
Reply to the thread, titled "Mira decor shower water running continuously from the shower head" which is posted in UK Plumbers Forums on Plumbers Forums.
Fusion,
Fusion,
