Neighbours boiler Flue into back garden
View the thread, titled "Neighbours boiler Flue into back garden" which is posted in Boiler Advice Forum on UK Plumbers Forums.
typical builders earn thousands out of the extention but move the existing boiler which is nine years old so the plumber gets as little as possible from the job
personaly i wouldnt contemplate moving a boiler that old
They have already spent the money on Kitchen furniture to go where the boiler was.
So they want everything all ok for them and s*d the neighbour. They should have factored in the cost of the new boiler, taking into consideration that the existing boiler could not be fitted elsewhere without needing horizontal flue over neighbours garden. I am sure they must have checked with an installer whether the boiler could have had a vertical flue fitted through the roof. The silly thing is that when I had a new boiler fitted, the neighbour commented about the fact they probably could not have flue fitted over my garden. This was a few years ago, so they must have checked. So why 2 days before they mentioned about work for re-fitting the boiler and me saying I am not sure they can, so they must check, do they just go ahead as already planned. I think they just thought I would not have a problem. That they could do what they like. I even told them that if they went ahead with permission, I would need to make sure I was legally protected against future issue with this, as I was thinking of selling.
Techincal bulletin no 16 from Gas Safe Register 1st April 2009, applies apparently. So if this is the case that the TB is current, why would Gas Safe Registered people be willing to overlook this. I realise there are a lot of rules and it can be confusing, but when a client asks for work to be done, shouldn't they check first? It would have saved a lot of upset and unnecessary hassle. If the neighbour had been advised, they would have had to allow for this when budgeting for the works. Why should I be dragged into a dispute that they should be having with their chosen installer.
"Terminal Requirements
The primary legislation concerning the safe installation, maintenance and use of gas systems and appliances, (eg in GB-the gas safety (installation and use) regulations (GRIUR)) in particular regualtion 27(5) states: "No person shall install a flue other than in a safe position." Guidance Note 182 of the Approved Code Of Practice and Guidance to the GB GRIUR then states:
"A flue(including any terminal) should be installed in a position which ensures that it will operate effectively and that products of combustion will safely disperse and not present a hazard to any person, whether in the premises in which the associated appliance is installed (eg by being located a safe distance from vents and open-able windows), or in adjoining/neighbouring premises. The location needs to take into account any possible developments in neighbouring property, eg building extensions. Any flue should therefore be sited so as to discharge at a safe distance from any boundary with adjoining premises; references should be made to requirements in Building Regulations and appropriate standards, as applicable."
And 6 metres away is more than adaquate
Your the one who seems to be couseing the problems
Gray
I think the balance of opinion is that if the flue is to be over the boundary, that they should have asked for my consent. Not tell me lies, as part of vague consultation with me and then to go ahead with the work as planned, without my consent.
I allowed them several years ago to use my garden to assist them when they were building the bl**dy extension that is on the boundary and I often take in parcels for them.
I have been a good neighbour and now they repay me, by trying to pull a fast one. I only asked them to check the various regs for compliance. Had they come back with the details and reassured me in writing they they would move the flue on request at any time, I would have hapilly consented. This what being a good neighbour is about. They tell you the truth, ask nicely and give me the chance to make any reasonable request. Not just go ahead with the work, without consent.
Getting a bit silly mate, you have already stated that you havent got a problem with flue, your problem is that they lied to you.
Therefore refuse to let the flue terminate over your boundary, they cannot install the boiler, therefore you win, job done.
Last post on this thread for me.
im unsure why its not a condensing boiler if new install, particulalrly when youve been talken to building reg people
I wasn't going to post again.
But to answer the q, the boiler is non condensing. It is re-siting of the current boiler. The building reg bod at the local council said they thought the boiler might need replacing, but it would depend on the what the current boiler was. The GSR installers, would I expect have some reference book to refer to, to inform them. But I a not sure whether the work to re-site the boiler would have been registered.
Personally I wouldnt agree to it, not for safety reasons etc as it is perfectly safe from what you have described but purely because of the issue with regards to selling your property in the future. Under the regs they shouldnt be terminating a flue in your property so anyone who buys your property in the future is fully within their rights to ask for it to be removed. The last thing you want is a bone of contention with future prospective buyers. From the sounds of it you dont want to allow it anyway. As an impartial observer I would say that the neighbour is making a reasonable request (although it could have been more timely) but it is also reasonable for you to object and personally (for the reasons mentioned above) I would.
jonesy end of day its your house mate - not greys not anyone elses - you know your situation and now you have the regs - i personally wouldnt let any flue exit over any of my property and i wouldnt install it that way either or ask for it too. I dont think your a neighbour from hell and totally understand your view point - its up to you at the end of the day. even if it was a middle terrace then they would still have 2 sides and a roof to find some place to site the boiler - surely they can sort this out.
TB 16 that you are referring to is regards condensing boilers.
Prior to around 2004 you could stick a flue anywhere but the rules have changed and permission is now required but it is not a gas reg it is a building reg so speak to the BC officer.
Remember while you are there to complain about any gutters that may also be overhanging as it is an almost certainty that one day they will leak water onto your land or worse have to be replaced.
Like Gray, thank god i don't live in London. We have better things to fall out about up here🙁
It is not london, but a modern housing estate elsewhere. I think when planning is done and additional consent is given to extensions, sometimes future boundary issues are overlooked (pardon the pun).
I probably came over as a bit angry the other day, which I was. Calmed down now. It was just that the neighbour assumed I would not mind the flue over the boundary and was going ahead with the work, even though I raised concerns 2 days earlier when they 'consulted' me . I did ask them to check the various regs to make sure ok and expected them to come back to me. I had not expected that I should have to look into the various regs, on the day they had the work planned for.
Anyway, I think they are now having another boiler with the flue through the roof.
Out of this I would say the learnings are.
If you are planning work near the boundary, which is not urgent, make sure you give the neighbour plenty of notice and ask them for their consent, if anything is to come over the boundary. The neighbour might want to check for themselves about any issues, before they offer their consent. Also as the home owner planning the work, it might be a good idea to also check for yourselves. All it would have taken were a few phone calls e.g. Gas Safe helpline, local council building consent people.
Leaving it just 2 days before the actual work is to take place, to just consult the neighbour and then to go ahead with the work even after they had raised concerns is not a good idea. The various regs are just too complicated to leave it until the last minute.
I would have thought that when existing boilers were re-sited, that the GSR person doing the work, would have made sure that all the regs were complied with and any consents were obtained before they did the work. I don't think I would conduct work, putting something over a boundary, if I could be called back later to do more work for free, if there was a dispute later.
The GSR would not have to move the boiler as he / she would be working under the clients instructions, personally I would want the instruction in writing but thats me.
It is possible your neighbour was not aware their existing boiler was not suitable and may have been advised of the need to replace it just before consulting with you because many builders would not know the difference between different boiler models.
As you have to live beside the people for at least the foreseeable future I suggest you give them the benefit of the doubt as none of us are mind readers, it would be sad to lose a good neighbor (both parties) over a misunderstanding.
Reply to the thread, titled "Neighbours boiler Flue into back garden" which is posted in Boiler Advice Forum on Plumbers Forums.
Jonsey67,
peteheat,
