New DIY "Plumber" needs advise for loft water tank supply nut and olive?!?
View the thread, titled "New DIY "Plumber" needs advise for loft water tank supply nut and olive?!?" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Hey guys
I've "repaired" my mums loft water tank from leaking but I'm unsure if I've done it correctly so thought I'd join this great forum and ask some advice from some people much smarter than me.
Basically my Mum was worried that her overflow from the loft kept running water so I went round and had a look thinking it was the Float Valve,turns out I was right as it was trickling and overflowing,it was also the old part 1 type from what I understand. I fitted a new one in my own tank a few months ago so knew what to do.
The tank was filthy inside and also full of rotten wood which was odd. After checking all the nuts I told my mum that it would be fine until the next day when I could pop and get her a new one. When I got back home she phoned me in tears saying the roof was leaking,so I went round and turned her water supply off and drained the tank as I couldn't find the isolation valve.
I then noticed there was a leak in the supply nut on the outside of the tank (on the right of the photo) going into the float valve. I can only guess I loosened it my mistake when I was checking things by hand.
The next day I got the new valve,float and a washer kit just in case. Gave the water tank a good clean,removed all the limescale and fitted the new float valve. Tightened everything up and turned the supply back on. There was still a major leak coming from the supply nut where the pipe goes into it,so the water was turned off again quickly.
I completely removed the back nut to look inside and I couldn't see any kind of washer or olive? I found this odd as I always thought a nut connection needed one? Also my parents have lived there for nearly 40 years and they've never had a tank leak before.
I'm really not sure if I did the right thing here but I found a right sized olive in the washer set and placed it over the pipe under the bolt and reconnected and tightened everything up. Water came back on and everything looked ok. I had a coffee and then went back up to check 20 mins later. There was a slight bit of moisture around the nut where the pipe was connected,probably about a quarter of a drip so I tightened it up more and everything's seemed to be ok since.
I'm going to pop by tomorrow and check things over. I'm just worried I did the wrong thing and things will start leaking again. Obviously being in the loft its hidden from view unless you go up and folks are getting on a bit now.
Could anyone give some advise and tell me if I've done anything wrong so I can put things right?
Thanks loads in advance and sorry for the long winded post,I just wanted to give as much detail as possible.
Just so you guys can see here's a pic of the water tank before I butchered it.
Anyway its all done now and I'll sleep soundly tonight. Cheers guys,what a great forum.
One last thing...
I haven't read all 50 posts so this may have been dealt with already but you mentioned rotten wood in the tank. That was probably the remains of a lid that went on the tank. The tank needs to have a proper lid on it and to be insulated before the job is finished.
You can buy tank lids in standard sizes from plumbers merchants. There are places that will make custom sizes.
One last thing...
Cheers for that. I've cleaned the tank out and Ill get my folks to buy a proper lid from wickes or another supplier. Thanks for that!
You either need to remove the "Tap Connector completely and extend the 15mm pipe up an connect with a simple 15mm nut and olive - or get a 1/2" fibre washer to put on the "tap connector"
Reply to the thread, titled "New DIY "Plumber" needs advise for loft water tank supply nut and olive?!?" which is posted in DIY Plumbing Advice on Plumbers Forums.
Ghostrider17,
JayThePipe,
