View the thread, titled "old radiator pipework found" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
B
beakhouse
Hi there, I want to add a new radiator to my house, I was going to make the necessary plumbing via connections to an existing radiator.
However, I had a look under the floorboards and found a "spare" radiator pipe (at least it has a rad connection at the end). So, I thought great, I can use that. Then I thought, hang on, there is only one pipe. I traced it back to a central pipe, there is no return and I can't see any evidence of there ever being one.
Would a raditor ever work if I connected it to this pipe? There is no return.
What could have been connected to it?
Can I just add a return to the central pipe?
Or should I just extend the pipework from the existing rad I metioned?
Thanks for the advice.
Richard
Hey Buddy,
you need to check if your heating system is a 1 pipe system or a 2 pipe system.
if its a 2 pipe system just take a pipe off the other pipe so it can make a circuit.
Happy Plumbing🙂
Before you connect anything you need to be sure what the pipework is. Just because its got a rad valve at the end doesn't mean its a heating pipe, i've seen rad valves use as stop ends and drain offs before. Trace pipework back to be sure where it comes from.
Thank you all for your advice. I have considered it, had a looked at the pipework again and now know exactly what to do. Thanks again
Cheers
Rich
I added the return, fired up the boiler and the radiator comes up nice and hot, thanks again, you guys really helped me.
Cheers
Richard
hi i changed an old rad from the bathroom but now if i put just hot water on the heating comes on can someone advice me whats wrong its an old heating with back boiler and i cant find the diverter valve anywhere.thanks
regards
Imran
Reply to the thread, titled "old radiator pipework found" which is posted in Gaining Plumbing Experience on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
beakhouse,
imranhafeez,
