B
beakhouse
Hi there, I want to add a new radiator to my house, I was going to make the necessary plumbing via connections to an existing radiator.
However, I had a look under the floorboards and found a "spare" radiator pipe (at least it has a rad connection at the end). So, I thought great, I can use that. Then I thought, hang on, there is only one pipe. I traced it back to a central pipe, there is no return and I can't see any evidence of there ever being one.
Would a raditor ever work if I connected it to this pipe? There is no return.
What could have been connected to it?
Can I just add a return to the central pipe?
Or should I just extend the pipework from the existing rad I metioned?
Thanks for the advice.
Richard
Hey Buddy,
you need to check if your heating system is a 1 pipe system or a 2 pipe system.
if its a 2 pipe system just take a pipe off the other pipe so it can make a circuit.
Happy Plumbing🙂
Before you connect anything you need to be sure what the pipework is. Just because its got a rad valve at the end doesn't mean its a heating pipe, i've seen rad valves use as stop ends and drain offs before. Trace pipework back to be sure where it comes from.
Thank you all for your advice. I have considered it, had a looked at the pipework again and now know exactly what to do. Thanks again
Cheers
Rich
I added the return, fired up the boiler and the radiator comes up nice and hot, thanks again, you guys really helped me.
Cheers
Richard
hi i changed an old rad from the bathroom but now if i put just hot water on the heating comes on can someone advice me whats wrong its an old heating with back boiler and i cant find the diverter valve anywhere.thanks
regards
Imran
