View the thread, titled "Only one working radiator" which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
That's it, I would say pump but without checking the voltage to the pump can't be 1000% sure
Can I suggest before ripping it out disconnect the pump supply and put it on a plug and extension lead to try it. it wouldn't be the first time I've found dodgy switch contacts meaning the pump isn't getting voltage.
I may get someone to do it for me as there seems to be a lot involved. Can't find a drain valve now. Any ideas of what I should expect to pay for this?
But then the display wouldn't light up ?
And op your best having a few plumbers quote
Basic version: dodgy contacts can cause high resistance. When the pump is off load the voltage is high enough to run the display. When the pump load increases the resistance causes the voltage to drop. LED displays don't need much to run but motors do, hence the 'fault'.
Did you check and make sure the system has enough water in it before you rip anything out or a fill valve needs to be turned on system might be just going dry not enough water in it and the boiler will keep going to lock out
Just call your local plumber in I,d say it just needs to be filled and tested maybe a bit of balancing to be done nothing major get to have a look at the old leak on the trv pipework as well I recommend
Whoever wired the pump didn't do a very good job. Might be worth unplugging and checking the connections are tight.
What speed is the pump on? If it's on Autoadapt, try each of the fixed speeds in turn to see what effect it has.
Reply to the thread, titled "Only one working radiator" which is posted in Gaining Plumbing Experience on Plumbers Forums.
Thread starter
Joined
Location
Titchfield Common
DIY or Homeowner
Thread Information
Title
Prefix
N/A
Forum
Start date
Last reply date
Thread Tags
Tags Tags
radiator
CHRI1111,
Dkdc71,
