Over 3 mins to get hot water in kitchen - is this normal?
View the thread, titled "Over 3 mins to get hot water in kitchen - is this normal?" which is posted in Bathroom Advice on UK Plumbers Forums.
L
LCV
My family have just moved back in from a house renovation just before the Easter bank holiday. When I turned on the tap in the kitchen to wash up and it takes over 3 mins before the water was hot enough to wash up. I had a large kitchen sink put in and I managed to fill that up with cold water which I had to then drain away to replace it with the hot water. It would have been faster (and used less water) if I had boiled the kettle for the hot water. I now wash my hands with cold water after I have used the toilet because it takes so long and as a family so much water is wasted while we wait for it to be hot enough to bathe and shower.
I feel concerned. Is this normal? Before the renovation I did not have to wait long to get hot water to all my taps.
We had a Vaillant system boiler with a 250L indirect hot water cylinder put in. The previous combi boiler was moved from the kitchen to the Utility room. The kitchen is at the front of the house while the Utility room is at the back of the house on the same floor. The previous house was over 3 floors with 2 bathrooms and a loft conversion has taken it to 4 floors and 3 bathrooms. We were told that we would have to wait up to a minute to get hot water in the loft which we said we were fine with but it is actually a lot longer than that and we certainly did not expect the rest of the house to be affected in this way.
I will go back to the plumber to discuss but wanted to get your views and advice first. I am really hoping the problem is to do with a setting on the boiler.
Thanks!
Hi and welcome.
No it's not normal. According to government guidance it should take be no more than 30 seconds to deliver water at 50c so as to conserve water and energy.
Poor design by the sounds of it.
Oh no....what can be done at this stage?
Is it the Plumber's responsibility to check this after 1st fix or is it my responsibility to have checked or specified that I wanted hot water as per government guidelines?
The responsibility is most certainly with him!
There are a variety of options available to you but most likely at this stage will be a local heat source such as a small unvented hot water cylinder under the sink.
Thanks Howie for the good advice. If you don't mind can you tell me the other options available to me so I can ponder over them before I meet with the plumber. I have sent him an e-mail to let him know and asked for him to come by next week.
Sometimes the design of the house dictates where things can be put. The farther away the hw cylinder (or combi) is from the taps, the more water has to be drawn through the pipes.
Your only solution is to put in what is called a secondary return (basically a loop of pipe and a pump)
This is how big buildings like say a hotel works. The hw tanks may be 100's of yards away from the taps but you get hw within 2 or 3 seconds.
Speak to your plumber about it.
I doubt you're plumber will want to pipe up a secondary return now that the renovations are finished. It's without doubt what he should have done in the first place but I'd imagine it's too late now.
If it's only the kitchen tap that suffers then perhaps consider an instantaneous water heater.
Hot was as per government guidlines lol... Good luck telling that to your plumber lol!
Sounds like a long dead leg to the kitchen sink, maybe due to the relocation of the hot hw cylinder etc... Maybe possible to reroute the pipe more direct etc, best get him back to check...
A secondary hot water circulation could also be an option or have the Combi feed the kitchen still & not the unvented system!
Thanks for your replies.
Is it too late to fit a secondary return? what level of work is involved to do this? The fastest time for me to get hot water is 52 secs in the toilet on the ground floor. The tap in the loft en-suite takes 4mins.
I still haven't heard back from the plumber. Perhaps he is busy....
I meant after speaking to the plumber (when he gets back to me). I've just discovered that he has fitted my shower incorrectly. When I turn on the shower the hand rinser comes on instead of the shower head so I am losing a bit of faith in him.
It is not a digital shower. It is a Hansgrohe manual mixer that operates like single lever tap so lift up to turn water on and swing it to the left for hot and right for cold. You pull the diverter to divert the water to the hand shower. In this instance he has installed it the other way round.
Reply to the thread, titled "Over 3 mins to get hot water in kitchen - is this normal?" which is posted in Bathroom Advice on Plumbers Forums.
LCV,
rpm,
