Pipe Centres too Narrow for Bar Shower
View the thread, titled "Pipe Centres too Narrow for Bar Shower" which is posted in Showers and Wetrooms Advice on UK Plumbers Forums.
Hello,
I’m having a bit of an issue trying to fit a mixer shower bar, the pipe centres are around 3/4mm too narrow! I’ve attached a photo below, is there a simple fitting I can by to narrow the pipe centres by a few mm?
An experienced plumber will know how much 'persuasion' the pipes can take and I'd imagine with mastic removed and a little prep that that difference can be persuaded.
If not then im afraid its nocking out some tiles or cutting access from behind
I have a plumber coming tomorrow to have a look. I’ve also bought the below as a back up as it says the centres are adjustable +/- by 25mm
Reply to the thread, titled "Pipe Centres too Narrow for Bar Shower" which is posted in Showers and Wetrooms Advice on Plumbers Forums.
liama123,
liama123,
