Well, we all know it doesn't. Or rather, you can mostly get away with the pipe only just inserting into fitting when in a tough situation.
Whether it be copper into compression or end feed or waste pipe into fittings I've yet to have a leak when circumstances force me to insert only a little into fitting.
My question is why would you need to anyway? Is there a genuine reason why that joint is less likely to stand the test of time than one fully inserted? I've pulled apart no end of joints that look 25 years old or more with a microscopic bit of copper protruding past the olive. I mean if it was that necessary they wouldn't make slip couplings. I just feel slightly guilty when I have to resort to it because no play in pipes or not enough to work with like I've bodged it to a degree...but is it a bodge at all?
