When i did some work for BG, they supplied pipe sleeve's for 22mm pipe, it was white and fitted tightly over the pipe, meaning drilling a smaller hole. Anyone seen this anywhere??
You cant use hep as a sleeve??you could use 28 mm hep its a perfect fit for 22 and you can use 28mm core drill
It's not a grey area unfortunately it's in black and white.
If it makes sense or not may certainly be up for but debate but it definitely states all sleeves must be suitable for the safe carriage of gas.
I always use copper, seen loads of waste pipes and overflow used when doing CP12's and always gets noted.
A lot of specs for bigger jobs we do also state the sleeve should be two pipe sizes larger than the pipe passing through it. So for a 22mm pipe you'd use a 35mm sleeve, dont think that's anything to do with GSR though.
Just a quick one, I found this in BS6891:2005. Just to confirm that some types of waste pipe can be used as a sleeve, so no need to note anything down on CP12's etc.
8.10.1 Sleeves shall be of a material capable of containing gas, e.g. copper, steel, polyethylene or polyvinyl
chloride (PVC).
so waist pipe can not be used ? what is waist pipe made off ,any one ?
chloride (PVC).
I’m well aware of the BS info and wouldn’t use the waste pipe as the sleeve. But, I had a quick chat with GS inspector and ex BG engineer (not at the same time), both said it’s OK to use the waste pipe as the sleeve. How about that!? 😕
and the supply pipe to the ecv is plasticSo why when you get a inset meter box the sleeve is made from fibreglass ?
