plastic pipe for oil tank feed to boiler
View the thread, titled "plastic pipe for oil tank feed to boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
F
froggy
would it be possible to use per /pex plastic pipe on a oil tank feed to the boiler,in place of the old copper one.
Hi froggy, welcome to the forums. Your better off posting this in the plumbing forum, you'll get a better response in there.
cheers
You need pipe fit for oil & underground...
Qual-Oil Pipe 50m x 10mm | Oil Tanks | NoLinkingToThis
You can use the pipe above but not many do because legally it cannot come above ground so you have to fit two inspection hatches either end and adapt it to copper before it comes out of the ground. The hatches must stay for ever to insect the joint for leaks. It is easier to just do the whole run in plastic coated copper.
Reply to the thread, titled "plastic pipe for oil tank feed to boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
froggy,
froggy,
