View the thread, titled "Plumbing in France, part 1" which is posted in UK Plumbers Forums on UK Plumbers Forums.
Plouasne
French Plumbing
Sorry that this is over 4 postings, it was too much for one posting, so please bear with me
There is not much difference between French and English plumbing at first glance, but when you have a closer look, its has different as chalk is to cheese
For a start not many plumbers do roof weathering, and there is not much lead used, its mostly Zinc (pronounanced 'zang') that is used for normal house work, and the plumbers do not normally concern them selfs with the guttering or the rainwater pipes, that is left to either the roofer (couveur) or the carpenter (charpentier) there are two types of charpentier, metalic or bois (wood), they are the people who do the roofing structure
Sheet metal roofing, copper, aluminium, and zinc is mostly by specialised trades men, lead is used on resturation work of old historic properties where lead had been used in the past
New work will have to be covered by a 10 year insurance guarante, renovations for 2 years, you are the professional and should know the regulations (or Norms) D T U, or document technique unified, DTU 60, for plumbing, DTU 61 for gas fitting, DTU 64, for drainage not connected to the sewer, DTU 65, for central heating, etc
Gas work
If you do gas work either you or your firm must be registered to an approved body, when the work is finished it is tested and if sound it is signed off, with copies going to the client, the clerk of works (if there is one), the supply company, the firm, all to be kept indefinitely, this includes new or replacement gas boiler and gas water heater work
General plumbing work
There is no such thing like the local council building control inspectors in France, for new works it is normally a Maitre d'Overture, similar to a cleark of works, who will oversee the construction
New estates are normally plots with the services to the boundary and a sub base road, where the buyer can pick what style of house they want from an architect or if the house is under 170² metres overall design it them self, and then choose their own trades men to build the property
Most of the work is carried out by small one man 'artisan's' or a firm with anything up to about 8 operatives, on their books
Self employed
To become an artisan, it is not just a simple matter of having a few tools and calling yourself a plumber, you have to register with the local Chamber of Metiers (Masters) who deal with your trade, then you have to go to school to learn about accounts the law etc, for a week then when you have passed the test, you have to find an accountant, an assurance company, then with that behind you, you can then get your siret number, this is your company registration number which then allows you to trade in what you have said you will trade in; unless you have written what you will trade in you will be restricted to that trade has the major trade with little else apart from minor works relating to the main trade, normally you will write in that you will do plumbing and electrical work, which most plumbers do, and also your VAT (TVA) number, if you have either elected to be a vat registered trader or your turnover will be big enough for you to be registered for vat
Its no good doing mostly electrical work, when your registration is for plumbing and god forbid if you are caught doing decorating or something similar, unless its a minor part of your contract, or even worse black work, thats a BIG NO No; because if caught the authorities can go back over your books and fine you double the amount under-declared, plus a 35000€ fine and or 5 years inside, if you keep on making a habit of working on the black
The person who employs you to work on the black, can also be fined, and if you have an accident you or the person who employs you will have to reimburse the state for any medical treatment and sick pay
The Gendarmes, Police National, and the Inspectors of work, have the right to go on site and demand to see all papers, assurance, and insurance, siret number, identification cards of foreign workers, etc
Material
Most of the pipework in houses is in copper tube with a wall thickness of 1 mm, and the sizes are in even numbers, dead hard temper and in 4 or 5 metre lengths, so you state the obvious when you ask for copper tube, (I want a bar of 8/10 tube, etc) the sizes start at, 6mm, i,d, / 8mm o,d, upwards in even sizes, you can also get coils (couronnes) of copper tube, in 5, 10, & 25 metre coils, unless the tube is clipped to the walls, it is run inside a plastic sleeve ( gaine, pronounced gan) whether it is buried in the floor or the wall, some of the coils of tube have a light plastic foam insulation with a smooth plastic cover, this is nearly all ways used for the heating circuits, and goes down has a first fix onto the concrete slab, before the screed (chappe) is laid, most houses have a a concrete block and beam flooring, (specially shaped hollow concrete blocks laid on to concrete inverted 'T' beams, for the first floor,and some times used for the ground floor as well
The incoming water main is normally in black MDPE tube with 4 sky blue stripes down the length, and is 20/25mm, o,d/i,d, the meter (compteur) pit is normally just inside the boundary and is a concrete box or circular ring 60 cm in depth, this also serves has the connection point for the telephone as well, the incoming main has a stop valve first, then the meter, followed by a class A, double drain off check valve with a loose female nut which is drilled to take a sealing wire, when it is fixed to the meter, the actual water main is laid in a blue plastic gaine 50mm in diameter at 60 cm depth minimum on a sand bed with 15 cm sand cover then a blue plastic grill is laid on top then another 15 cm of sand before it is back filled with soil
Pipe layouts fitting etc
The system is all mains pressure, so no cold water tanks in a cold roof space, quite often the roof is 'traditional' not like in the UK where its light roof trusses, and the space is used for the first floor bedrooms and bathroom, the water pressure is around 3 bar's, if it is more a pressure reducing valve is used at the point of entry
Although the plumbers are spoilt for fittings, they nearly always make there own, 'tee's', corner branches, even swivel connectors, it is always hard solder jointing, (99% Cu, 1% Ph) in Brittany, where I was working, and 99,9% of the French plumbers do the same, so you older plumbers look out your 'bent bolt', if you want to come and work in La Belle France, because they knock up nearly all their branches, and drift out and flaten the end of the tube to make a swivel connector, how its done, first anneal the end of the tube, then drop a loose nut down the tube, clamp the end of the tube in tool like an oil line flaring tool, flare out the end of the tube then turn the clamp over and flatten the end of the copper tube, and 'voilà', a tap connector, etc, unless you have put the nut on upside down, flared out the tube too much, then you must cut the flange back, or not enough and the nut falls off the end of the tube, but you will soon learn how much tube to turn over
Another thing that s different is that manifolds are used a lot, instead of a single pipe serving all appliances on a circuit, close to the hot water cylinder or the incoming cold water, a manifold is formed, normally out of 28 mm copper tube with the right number of branches to connect to the supplies which were left, when doing the first fix, the manifold is quite compact, with the branches about an inch (25mm) apart or less, these have quarter turn valves so that an individual appliance can be isolated, the manifold also has an isolating valve on the inlet, and a drain off at the far end, it is common for another set of manifolds to be used for the first, and subsequent floors
None of the fittings, like, tap connectors, or traps have a spigot to get in the way, you just bring the deep nut up slide in the fibre washer, then make the connection
Gas service
The Gas (Gaz) service is the same, MDPE execpt that instead of a blue stripe its yellow stripe, and it changes from MDPE to metal not less than 1 metre from the building, and run in a sleeve, all jointing to copper tube is by silver solder, and fittings MUST be used, instead of the 'stab in's' which replace 'tees' as used for water services, special washers must be used for natural gas when making a connection to a gas valve for the cooker, which must be visible and a push in quarter turn valve with a male thread on the end to take the flexible connection, which depending on its construction, has a life of either 5 years, 10 years, or an indefinite life, if its LPG its the same, apart from the washers which are of a different composition
The normal gas operating pressure is 20 mbar for natural gas, and 37mbar for propane gas
Test pressure is 40 mbar for 10 minutes with no drop, the testing kit is a battery powered compressor with a 50 mm dial manometer, 0 to 60 mbar, with a black moving hand and a red movable hand, this is either fixed to the meter connection or if its a bulk propane tank fixed to the connection which connects to the tank, once fixed start the compressor it will stop automatically, let the pipework under test stabilise then, close the valve adjust the red hand to be over the black hand, leave for 10 minutes, if there is no movement of the black hand, the pipework being tested can be considered to be sound
Re: Plumbing in France, part 4 Tools that are needed
Tools required which are not normally carried by an English plumber, with the French name
External bending springs: ressort a cintrer
Hand bender 14mm & 16mm: pince a cintrer
Socket forming drift, 6mm to16mm: appareil a emboiture
Flareing tool for makeing tap connectors etc: appareil a battre les collets
Pipe clamp: positionneur porte-tube et profiles
Allen keys: cles 6 pans, torx keys come in usefull a well
Flat open ended spanners, ring one end: cles plates or fourche; mixtes or oiel et a fourche
Something which is very useful; cles a pipe, this is a 6 or 12 sided box type spanner, shaped like a smoking pipe the shorter end or bowl is pierced so that the spanner can go over the exposed thread of the bolt etc
Chalk line, every thing is set out by chalk line
Oven dried sharp sand, Sable sec, with a small funnel, to pour the sand down the tube for sand loaded fire bending copper tube
Small angle grinder, Meuleuses, this replaces a hacksaw in most cases
Laser line projector, to give you a level line, vertical line, or an angled line to work to, this is the latest gadget
Not forgetting the generator, electrogen, most sites do not have electricity connected if its a one off house build
The hot water cylinders are normally wall hung, and anything over 150 ltrs can get a bit "meaty" if you are on your own , and trying to get it to hang on the bolts as close to the ceiling has possible
W/C's are bolted down to the floor, with S/S bolts the, the bolts go through a nylon washer which looks like a BSS ball valve seating
If you are coming to do some work in France remember to bring the power tool transformer as well as the power tools, because all site voltage is 230 volts, just change the plug on the transformer or make up a flying lead with a UK socket outlet and buy a French plug when in France; DONT rely on adaptors because they can melt or burn out, all site electrics have a protected 30ma 30msec r,c,d, installed normally in a special works meter and circuit breaker water tight box suitable for use on building sites
A few other observations since I started these notes, one that I should have brought to notice before
In France its 99,99% single stack plumbing, with no idea of a vent or anti syphon pipe, (if it 'gurgles' just fit an air admittance valve in the line) and there is only one trap (syphon in French) seal depth, approximately 50mm water seal, and again most of them are bottle traps, even the bath trap, a Bidet trap is a little more squat than a Basin trap, some of the older (and not so old DIY) soil pipes terminate with the open end of the branch where it passes through the wall, it could be just an open end or it might have a reducer fitted in to the top of the branch with a couple of 40mm 90° bends as the vent, or the pipe might even run straight to the w/c with not a hint of a ventilation pipe
If a solid fuel fire with back boiler is used to run central heating, it is the requirement for this to be an open system, with a metal expansion tank at high level; most of the wood pellet boilers have a system to drown the fire in case of burn back, and also in case of pump failure / power cut, an over heat valve opens the cold water supply to cool the water in the boiler, when the safety valve lifts
Cross-linked polyethylene pipe either red or blue, with brass inserts and a brass outer sleeve drawn over the insert, with or without a protective gaine and sometimes pre insulated as well is being used a lot more these days, owing to the continual rise in the price of copper
Unless the walls are stone or its a timber frame construction, most external walls are either (Parpang) concrete block solid with small holes in them about 3 lines in a 200mm block, 25mm dia, and heavy; above foundation its a hollow concrete block 25cm x 50cm x 10cm 15cm or 20cm thickness the blocks themselves are normally 25mm wall thickness and either have 3 or 6 cavities in the block, or it can be light weight concrete block, more often its a red clay block with a multitude of small box like cavities in it; internal walls can be a multitude of things, (and like the external walls, damed difficult for a plumber to get a good fixing to hang any thing on the wall) these can range from 2 sheets of plasterboard with an egg carton divider, plasterboard on studs, metal or timber, thin hollow terra cotta blocks 35mm to 50mm thick, plaster blocks hollow or solid, and like the plasterboard used in a wet position, coloured green with a light waxy feel to them, these plaster blocks have a T&G edge to them and are jointed with a plaster adhesive called MAP, which has a multitude of uses when making good because its a bit more stickey than normal plaster, and does not set has quick as normal plaster does, which brings me to the plaster and how its applied to the walls, normal large areas of plastering are sprayed on, ruled of with a long, 2 to 3 metre straight edge, then towelled up, maybe 3 or 4 hours later, after wetting down with a hose, normal plaster is plaster of paris, and is used to joint the internal terra cotta block walls, this is an absolute sod, there is no other word to use, to work with, untill you get used to working with it, because one moment its liquid and will not stay on the trowel, the next moment its a solid lump, the art is to keep knocking it back
With all the tools to carry around, this often includes a generator together with the almost mandatory small set of oxygen & acetylene cylinder, small sack of plaster / MAP, and sand & cement, for making good, together with the dust pan & brush, most plumber / electricians, have a high top long wheel base van, this is racked out inside for fittings and fixings
The work I have done in Brittany, France, ranges from normal domestic house plumbing, through schools, shops, supermarkets, factories, and last but not least, and a lot of it as well, was central heating for pigs, one piggery was over a thousand head strong
The DIY sheds also sell glued pvc piping for hot and cold water, and push fit, fittings with a grab ring to hold the pipe in place, these sheds are handy for a stranger to have a walk around to see how the work is done in France, because they all have documentation and quite often a part built display on how to do it, they also sell a good range of well known, fittings, sanitary appliances and brass-work
Castorama is part of the Kingfisher group (B&Q in the UK), Leroy-Merlin, is part of the Auchan hypermarket chain, both have a good reputation in France, are open when the normal suppliers are shut, often 8am to 8pm monday to saturday, but do not give such a good discount to registered trades persons as the trade outlets, no shops apart from a few food outlets are open on a sunday
Sorry I cocked it up a bit when I tried to edit the postings
I hope that I have managed to attach a photo of a horizontal cylinder showing the inlet with the Groupe de Securitie, and trap, also above it a drain off, because its a bit of a cow to dribble bleed 200 ltrs of water through th GdS
Thanks Plouasne for the Plumbing in France info. I dug it up because I have been asked if I would be interested in doing some work in France with a small UK outfit who are going out there to renovate a chalet.
Interesting stuff, what are the main brands for boilers? Saunier duval and chaffeturd I guess?
nic e to see you back [DLMURL="http://www.ukplumbersforums.co.uk/members/plouasne.html"]Plouasne[/DLMURL]
This is frankly uncanny as myself and my girlfriend are going out to Brittany (Serent) in Febuary to live with my girlfriend mother (unfortunately her partner passed away) for a year and maybe more so I was starting to accumilate relevant information but your post answered most of the questions I had straight off the bat. Do you think I stand any chance of getting a job whilst out there ? I have been out to Serent three times now and have made a few french friends one of which is a builder so we will see. Plouasne would it be ok to send you a private message ?
Anyone know what happened to Plousane? I know he wasn't very well at one point. Hope he's OK
No replies unfortunately, which is never good news!
Nice to read about someone who has made the transition from UK to French plumbing.
Also good that he knew French so well.
My friend in the south has a lot of English friends and most of them can hardly speak any French at all even those who have been there for more than 10 years.
In fact only two speak French well, one a younger wife who works in the Casino and a fellow with a French wife!
Tony
Reply to the thread, titled "Plumbing in France, part 1" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Plouasne,
1Steven,
