E
eimaj12000
The washing machine upstand is being used by the washing machine and a dishwasher (it's always been used in this way since we moved in). It has a u-bend but there is no other seal I can see i.e. the waste pipes from both machines are just shoved inside the plastic upstand pipe. Could this cause issues elsewhere ? Things are developing now and they will be coming back out. The water temperature is varying i.e. it will be hot i.e. 50-60 degrees but then go to 20-30 degrees and back again. The only way I can get constant hot water is to turn the tap well down (to a near dribble). Upstairs it's much worse - the water is just not warm enough for a usable bath, yet the shower seems fine ? Also, the water from the hot tap is cloudy ?
I read somewhere else that in Scotland (where I'm located), it's best practice to use thermostatic mixer sets for the bath etc. is this correct (since the kitchen and bathroom taps are of the basic mixer type) ?
One thing that may be important here is that after checking and cleaning the washing machine upstand pipe (and hearing the 'hiss' noise as mentioned before), the bathroom upstairs did not seem to smell quite so bad for a while ? It's back to normal now though and neither the washing machine or dishwasher have been used.
The guy in charge is going to speak to the installer to check with him how things were done etc.
One thing I'm still not clear on after checking the recommended condensate routes for Worcester boilers - should the condensate line be going under the floor, angling upwards, dipping down, then up again etc. ? Just as from the manual they seemed to clearly show a downward angle along the full length of the pipe ?
Thanks for the assistance as this has been causing sleepless nights and from talking to this guy it's going to be a battle to get anything done.
