stevejd58
system;
Charnwood LA50iB multifuel room heater
Honeywell ST9400C programmer
Honeywell HCW80 wireless room thermostat
Grundfos Alpha 2 pump
minimum return thermostat
When the fire is lit we have the programmer set to continuous as I can't see the point of timing the pump on a system that is always on when in use.
I have noticed that on occasion the pump cuts out and none of the controls will re-activate it, this primarily happens when we burn wood as the system runs hotter, usually after an hour or so of running.
I'm beginning to wonder if this is a safety cut out but question this as I thought the min return thermostat was meant to kick the pump in to ensure the system doesn't over heat. I beginning to wonder if it has been wired correctly
Can someone explain how this set up is supposed to work
