Your type of system is a typical pumped heating gravity hot water system.
The only difference is there are 2 circuits on the heating side. The open vent cold feed will connect into the cylinder flow and return(gravity side).
The best thing you could do is convert the system to a fully pumped setup. Cylinder thermostat to control hot water temp and set it up as a s plan plus. As you the system you have now cannot have a new boiler simply added to it.
Seperate electrical feeds to pumps etc is just a bodge and could potentially be a hazard as the heating system should be fed by one fuse spur.
As its also a old type of system chances are it could be a 1 pipe system and trvs won't work properly anyway.
Reverse circulation will be caused by poor system design we're the circuit downstairs has been added on poorly.
So my advice if your renovating would be start over and do it properly otherwise you will give yourself a head ache.
