Replacement Boiler Advice
View the thread, titled "Replacement Boiler Advice" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Grateful for any advice regarding this problem.
Flat about to be let and main heat exchanger in Worcester Bosch Greenstar 24i Junior has failed!
I can replace with identical model (I think!) but would prefer to use GC2000iW C if possible. Question is, can the 2000 fit directly onto the 24i mounting frame? If so, it's going to make installation a helluva lot easier!
Appreciate any advice.
There's very rarely ever a 'straight swap' so I wouldn't pick the next boiler on that reason. It's a days work normally including a bit of pipe adjustments no matter which manufacturer/model etc.
We fit a lot of Baxi 800's in our rentals, they are great value, have a good warranty and easy to install.
You seen they’ve updated to the newer model ?
Reply to the thread, titled "Replacement Boiler Advice" which is posted in Boiler Advice Forum on Plumbers Forums.
PhilTilson,
ShaunCorbs,
