Jun 24, 2023
Somerset
DIY or Homeowner
Grateful for any advice regarding this problem.
Flat about to be let and main heat exchanger in Worcester Bosch Greenstar 24i Junior has failed!
I can replace with identical model (I think!) but would prefer to use GC2000iW C if possible. Question is, can the 2000 fit directly onto the 24i mounting frame? If so, it's going to make installation a helluva lot easier!
Appreciate any advice.
There's very rarely ever a 'straight swap' so I wouldn't pick the next boiler on that reason. It's a days work normally including a bit of pipe adjustments no matter which manufacturer/model etc.
We fit a lot of Baxi 800's in our rentals, they are great value, have a good warranty and easy to install.
You seen they’ve updated to the newer model ?
I've seen the marketing material promoting the new version but not an actual boiler, has much changed? We're heading to the Installer show on Thursday so was hoping to have a look at one then.
Yep quiet a bit new prv and condy layout and pushfit now
Also new insides
