Secondary heat exchanger.
View the thread, titled "Secondary heat exchanger." which is posted in UK Plumbers Forums on UK Plumbers Forums.
I think I’m going to get the secondary heat exchanger changed on my Baxi Platinum 28HE as my heating engineer has already cleaned it out a few year ago. My hot water is now once again fluctuating warm/hot as it did before. As a point of curiosity is there much difference between a 16 plate and 20 plate replacements available. Just trying to keep cost’s down too, thanks for any replies ?
True, but you've probably been to more blocked plates with no filter than you have with.
What I have found, is the standard of cleanliness of systems since magnetic filters has got worse. So many installers have the attitude of ‘ it’s got a filter now, doesn’t warrant a chemical flush’
Which plate heat exchanger would you choose...genuine ask
I might want to exchange 30 kw
I don’t quite get your question Rob, the plates are on boilers or heat banks. So you’d have to buy the manufacturers if replacing
ok , sorry what I am intrested in is a seperate heat plate heat ex. to transfer 30kw from one side to the other. its a notion I have had for a while since I advised the largest nursing home in europe about something else...they were using local plate heat ex. to provide
domestic hot water at mains pressure to numerous sub sections of the building from a central heat source via a 4 inch primary circuit ...just thought you might know as you are keen about them regards Rob
Like knappers has mentioned, it’s used in other set ups.Aren’t plates used in district heating pumping modules?
I’ve only ever had one that was impossible to block and that was a Grant vortex oil combi
Fitting an external plate heat exchanger to the system with own pump circuit. The photo shown is on to a old one pipe cast iron system sperated by a plate to the new pressured stytem.
As others have said I'd let the GSR engineer get the parts as the heat exchanger is sized to Rubbish the specific design and output of the boiler it is fitted to. Multiple different sizes of plates normally just indicates there are various output models of that boiler range.
Fitting a different type can negatively impact performance.
Also as mentioned get a filter put on at the same time. The system will already be drained for plate replacement so best to get one fitted at same time.
Reply to the thread, titled "Secondary heat exchanger." which is posted in UK Plumbers Forums on Plumbers Forums.
Canton,
EvilDrPorkChop,
