May 5, 2020
86
DIY or Homeowner
Refurbishing a bathroom - cold water is mains fed, hot from combi. There is a main service valve to the whole system where the supply enters the house. Do I need to have service valves on bathroom sink, shower and bath? Normally if I have to repair/replace anything I just shut off the main valve.
They’re not required, only one required is on the toilet. It’s good practice and if you wanted to I’d recommend full bore ones.
Reactions: SimonG
Personally I think they're pointless. They leak for fun and more often than not you end up replacing them as well as the tap you are isolating.
As above, if they are easily accessible afterwards and you turn them once a year to keep them active, it might be seen as good practice by some.
