service valves or not
View the thread, titled "service valves or not" which is posted in DIY Plumbing Advice on UK Plumbers Forums.
Refurbishing a bathroom - cold water is mains fed, hot from combi. There is a main service valve to the whole system where the supply enters the house. Do I need to have service valves on bathroom sink, shower and bath? Normally if I have to repair/replace anything I just shut off the main valve.
They’re not required, only one required is on the toilet. It’s good practice and if you wanted to I’d recommend full bore ones.
Personally I think they're pointless. They leak for fun and more often than not you end up replacing them as well as the tap you are isolating.
As above, if they are easily accessible afterwards and you turn them once a year to keep them active, it might be seen as good practice by some.
Reply to the thread, titled "service valves or not" which is posted in DIY Plumbing Advice on Plumbers Forums.
mitchino,
SimonG,
