Still can't understand how it's a balancing issue as no radiators are " over heating " ie robbing the others. I can see how you can balance the rads to share heat output but without valves in the pipework circuit what other " balancing " can you do ? can you explain your theory / potential fix.like i said balancing issue right at the start. its a pain in the but to sort some times done 2 last year.
God help the plumber on this job.Still can't understand how it's a balancing issue as no radiators are " over heating " ie robbing the others. I can see how you can balance the rads to share heat output but without valves in the pipework circuit what other " balancing " can you do ? can you explain your theory / potential fix.
