Sky up again
View the thread, titled "Sky up again" which is posted in UK Plumbers Forums on UK Plumbers Forums.
all ears!
just dumped sky and signed up to virin big knacker or something, no tv.
pictures i can follow lol
got an old roku stick, is this good enough or do i need another-which one?
start the post and i will close it until your ready. kj
You will need a amazon fire stick or fire tv box
thank you for your efforts, havent a fecking clue what your on about, but I'm more luddite than nerd
No mutley the fresh start should delete everything apart from kodi and ares wizard.
From ares wizard just select browse builds and select pulse ccm (59m) Then follow rest of the instructions
thanks kay jay, I just bought one for the old man, downloading the Jarvis file now, I presume ive picked the right file to download...kodi 16.1 Jarvis armeabi-v7a which is the latest version, 55mb odd.
theres another one the same but its only 11mb and it says symbol after it, I assume I don't want that.
That's correct pal.
Let me know if it all works for you
Just out of curiosity on our Kodi at home we just have a K (lodi logo) and on others i have seen other logos With the K and an ES app next to it .
Apparently that app helps run it can that get out dated??
That's correct pal.
ive hit a snag, its all connected on adb so ive clicked file then download, selected arm, then ive clicked on kodi 16.1, it then brings up the internet explorer download thingy, so ive saved it to desktop, when I go into adb after its downloaded ive clicked on install apk it doesn't show up on the file explorer?
I have Kodi with Wookie. Can't fault it really. Ditched Sky and BT and all i have now is 70mb fibre and everything i need. 😀
Well done Jay!
im on ares now, when I click install on pulse ccm it says download failed, not a valid zip file, is there another build you would recommend?
thanks in advance.
So I did all the start new stuff and couldn't find builds. I have loaded Aries nut when I go to zulip file Aries and click there is nothing in the file?
You should still have ares wizard after fresh start.
From ares wizard there should be a browse builds link.
Reply to the thread, titled "Sky up again" which is posted in UK Plumbers Forums on Plumbers Forums.
townfanjon,
clarky101,
