Sky up again
View the thread, titled "Sky up again" which is posted in UK Plumbers Forums on UK Plumbers Forums.
thank you for your efforts, havent a fecking clue what your on about, but I'm more luddite than nerd
No mutley the fresh start should delete everything apart from kodi and ares wizard.
From ares wizard just select browse builds and select pulse ccm (59m) Then follow rest of the instructions
thanks kay jay, I just bought one for the old man, downloading the Jarvis file now, I presume ive picked the right file to download...kodi 16.1 Jarvis armeabi-v7a which is the latest version, 55mb odd.
theres another one the same but its only 11mb and it says symbol after it, I assume I don't want that.
That's correct pal.
Let me know if it all works for you
Just out of curiosity on our Kodi at home we just have a K (lodi logo) and on others i have seen other logos With the K and an ES app next to it .
Apparently that app helps run it can that get out dated??
That's correct pal.
ive hit a snag, its all connected on adb so ive clicked file then download, selected arm, then ive clicked on kodi 16.1, it then brings up the internet explorer download thingy, so ive saved it to desktop, when I go into adb after its downloaded ive clicked on install apk it doesn't show up on the file explorer?
I have Kodi with Wookie. Can't fault it really. Ditched Sky and BT and all i have now is 70mb fibre and everything i need. 😀
Well done Jay!
im on ares now, when I click install on pulse ccm it says download failed, not a valid zip file, is there another build you would recommend?
thanks in advance.
So I did all the start new stuff and couldn't find builds. I have loaded Aries nut when I go to zulip file Aries and click there is nothing in the file?
You should still have ares wizard after fresh start.
From ares wizard there should be a browse builds link.
Hi Kev, I understand that to use the Amazon stick is OK. Would you say that a guard android tv box with 2GB of RAM is better?
So I have been on the ares forum and it is having issues with where the repo is saved at. This is why we are getting not correct zip file. I have not registered so could no find out more
Hmmm it was fine yesterday.
From browse builds screen choose a different build until it's resolved.
I have a zoomtak android box, connect to modem with a cable not wifi, its more stable. I also have a firestick so i can compare the two
I bought my zoomtak from 'tv box company' Comes with everything you need, im very impressed
I will try and find a workaround for the problem with the wizards.
But for the moment it looks like this isn't going to work so be patient.
So I chose a different build (brains kodi) it was the only one I could get to work. Not a lot of things work on it so hoping pulse will be alright soon. Cheers Kay Jay
I got pulse ccm to work. basically you load ares then go to programs then click on pulse then pulse ccm and it loads fine. did it on my laptop to see first, all ok, now done it on my box all hunky dory
Apparently pulse lite works
Pulse lite worked for me, watched the f1 on sky sports f1 hd channel on sunday with the old man so thanks kayjay...2 points to note though, the wifi antenna in the firestick is rubbish and no option to hardwire via ethernet so make sure your router isnt too far away before buying. Also make sure your broadband is up to the job of streaming without having to buffer. I tried it on another tv where i was only getting 2mb download speeds checked on a speed test and it wouldnt work
Buy a fire tv box instead of the stick. It has a hard wire port , more memory blah blah blah. Costs about a score more.
Only thing that worries me about amazon is you can't (easily) stop it self updating and i think in the next year or so they will cut kodi off.
I'll jump that bridge when it comes.
Reply to the thread, titled "Sky up again" which is posted in UK Plumbers Forums on Plumbers Forums.
townfanjon,
clarky101,
