Suggest gas combi boiler
View the thread, titled "Suggest gas combi boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Hi guys,
I`m looking for ultimate gas combi boiler, for underfloor heating, but struggling to find such. Can you advise? Must have following spec:
1. 24-30kw - 1 bed flat.
2. Stainless steel heat exchanger
3. Minimum of 12.3L/min at 35 degrees
4. Modulation 1:6
5. Minimum efficiency of 89%
6. No more than 40dB when burning at max
7. Consumes no more than 87w when burning at max and no more than 5w when idle
9. Brass/copper instead of plastics inside
10. Does have optional 7 day timer.
Thanks 🙂
and underfloor heating in a one bed flat lol first time ive heard of underfloor going in a flat
Because I don`t want to shower(at 40 degrees), then somebody starts washing dishes in kitchen and flow/pressure drops. Or washing machine starts running. I prefer to have guaranteed flow.
Why not? Radiators don`t look good, take up space, don`t heat efficiently. Also the kid and cat can enjoy warm floor(and me walking bare feet). And UFH cuts my gas bills. BTW its got high ceiling, not rabbit box newbuild, bigger than average.
kw doesnt = more pressure and if you want decent flow unvented system is what you want
Vaillant boiler for example:
At 42 degrees it provides 7.8L/min, but at 35 9.4L/min. It makes me think that getting higher kw boiler will give me more water at 42 degrees.
nope it slows the flow down to heat the water (so more heat = heating the water faster = slightly better flow rate) but if your incoming water flow rate is low your hot water flow will be less
and them figures are at about 15-20 lpm (main pressure about 1.5 bar)
Hi guys,
I'm looking for ultimate gas combi boiler, for underfloor heating, but struggling to find such.
I doubt there is such a thing made anywhere in the World.
Everyone uses plastics.
rpm, why not? I explained reasons in my post above.
Think you misunderstood my post, I`m replying (with the quote) to another post and saying there are some massive flats with massive floorspace around.
You are correct. By increasing the kw rating, you will either get more flow for the same temp, or a higher temp for the same flow. At the extreme top end of the combi market - around 40kw - 42kw, this is enough to support two concurrent outlets at very moderate flow rates. (say a basin tap).
But to get a constant temp and flow whilst running multiple outlets anything more than that, you will need either stored hot water, or a dedicated water heater from the light commercial sector.
What I`m trying to achieve - if I shower and somebody opens a kitchen tap, water flow doesn`t drop in shower and still keeps running at xxL/min at xx degrees.
The only way you'll get close to that is by having a boost pump just for the water inlet to the Combi.
Even then it won't be guaranteed.
Flow restrictors are the only way to achieve this. ecotec plus and pro use the same internal components plastic to metal wise. They are my boiler of choice though.
As per Ray`s post, its not a problem with amount of water supply to the boiler, but kw of boiler itself - ability to heat XX L water at xx degrees per min.
I have looked at Hansgrohe shower heads and taps - they seem to have water saving/reduction cartridges inside. Mixing water with air or something like that.
I`m leaning towards Viessmann Vitodens-100W. It ticks all the boxes, buts its 1:4, not 1:6.
so ?????? its still very energy efferent that all what matters
Do you even know the flow rate at the main incoming? Combis are not the most efficient for under floor due to hot water priority causing temp to drop away. Your asking a lot expect to pay a lot!
But its not most energy efficient. The difference is 8.3% from your boilers kw output. It all adds up. I would also like a boiler with passive flue gas heat recovery +it to work in condensing mode for hot tap water as well, but that`s asking too much 😀 Then I would need to manufacture one myself.
Reply to the thread, titled "Suggest gas combi boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
Depo,
Dan,
