Suggest gas combi boiler
View the thread, titled "Suggest gas combi boiler" which is posted in Boiler Advice Forum on UK Plumbers Forums.
I do care about my comfort. Why would I listen to the boiler noise if I can avoid that?
Does not matter which boiler you put in its never going to be silent, unless of course you leave it switched off which in your case I suggest as it might affect your comfort if god forbid your super dooper new stainless steel boiler makes a racket.
I suggest you speak to an Installer and get some advice and a quote and you choose the boiler because with the demands you have your never going to be happy with what is suggested. By the way expect to pay a few grand more due to your impossible spec your trying to work too and the stress your going to cause the guy. Personally no money would make me want to do the job with the way you've been on here.
I know I`m demanding customer, but hey - its my hard earned money and why should I waste it on medicore product, which directly affects my annual bills and every day living comfort?
Maybe I should organise boiler manufacturing? I would call it Ultimate Gold and it would have all the top specs and best quality components inside 🙂
It would be:
24kw
92.5% annual because it would have passive flue gas heat recovery
10.8L/min@35
1:10 modulation
Below 40dB when burning at max
Stainless steel HE +brass/copper components
Graphite seals
Colour 5" touchscreen
85w when burning at max, 5w when idle
I clearly am. I`m here, discussing with you all. Of course at this point I have already been told no such boiler exists and I will need to compromise.
Might not be 100% silent, but there is a difference between 55 and 40 dB. If you have choice, why choose noiser boiler?
these will help alot, and ignore the bog roll
I`m not mod and not winding anybody up - why would I? I`m just an ordinary guy who wants to buy best boiler available. I don`t buy installers/sellers sales talks, I always carry out my own research. I`m not plumber or heating engineer. I simply spent few days researching boilers, specs, technologies and spoke to few boiler manufacturers. Now I got some understanding what is what.
Best boiler on the market right now when you consider all aspects is an ideal vogue
You know, there is nothing I get more pleasure from than when I have a chance to learn something new from someone who has spent a day or so researching the subject on the internet?
My mere 3 decades of experience shrink to nothing compared with the titanic knowledge of the internet warrior. And my fellow forumites - those gas-safe registered engineers, business owners, college lecturers, and other geniunely knowledgeable people? I beg you be silent before the mighty wisdom of the forum tard.
Jesus H Christ.
Maybe, bear with me, I do oil, may be clutching at straws, but, and only maybe but. System boiler and unvented cylinder.
For gawds sake, its a one bedroom flat. Two people, tell them you will kill them if they open a tap when you are in the shower.
Ever heard the phrase 'anal retentive' ?
On a serious note.
If you go down the unvented route.
1. Check static pressure.
2. Check dynamic pressure.
3. Check flow rate.
4. Make sure the installer is g3 certified.
5. Make sure the installer doesnt make numbered lists. Really irratates the life out of me.
My opinion is you are worrying too much about the small things.
You are looking at figures why not speak to family and friends and see what boilers they have go and stand next to them and you will see that you will not hear them unless you are listening out for them.
On an 28kw combi there is a maximum flow rate that all manufacturers can get out using 28kw worth of gas and most manufacturers have got the most they can get on hot water rates this will still not be enough to run 2 taps at the se time without a temperature change.
You are on about the power consumption whilst idle and whilst running, instead of looking at things like that look at the cost of parts and the time it takes to change the parts, if 1 boiler saves you £100 in electric over 10 years but the parts are more expensive or harder to fit then it will lose you the money that you have saved.
To me the what anybody should be looking at is reliability, manufacturers aftercare and warranty. As you could find the perfect boiler that meets all your specifications and with a long warranty but if it goes wrong you could be without a boiler for a week instead of a day etc.
It does seem that you are being penny sensible but pound stupid.
didnt the OP say it needs to fit into a kitchen cupboard? this will limit many boiler choices and the option of recovery unit.
the baxi plat is a very loud boiler, the WB CDI classic is really quite imo. I guess it depends on the environment its tested in, most washing machines will be louder unless you get one of these
as your having a shower when the boilers making a loud noise and it will be on low for the UFH noise should not be a great concern
Reply to the thread, titled "Suggest gas combi boiler" which is posted in Boiler Advice Forum on Plumbers Forums.
Depo,
Dan,
