How do I get the thing out? I've tried turning every point I can & pulling but it just seems stuck in there. It only turns so far as you can see it's tight in there & I can't turn it anymore either way as the cistern stops it being able to.Yes the centre / one on the right when standing in front should twist 1/4 and you will find the washer has bubbled
If you use a torch to shine down the side of the valve you will see which way to twist as you will see the clips
Yes that’s the one I’m trying to turn. In the video it looks like it’s turned about half way but I cannot get that far as the cistern stops it from doing so as it’s in the way & doesn’t allow me to turn any further.The centre round one your turning ?
