feel sorry for you there mate, some customers are whollops. So she has a water pressure drop you mean which is why she contacted BG, who then point out the gas pipe may be undersized? Did they say may be or is? Maybe they just seen the 2.5metres of 15mm and assumed it was undersized without even doing a working pressure test? If you tested it and it was fine and there has been no appliances installed since then its unlikely the working pressure will have changed much isnt it? She sounds like a bad person and im sure karma will do its job on her.
good one TerryWhite , it takes 2 min to gas rate the boiler , if engineer did suspect it he would have quickly gR the boiler and check wp at meter and boiler ! please do not stress your self over it !
yes I have installed loads of boilers on 15mm where the supply could not be easily changed to 22mm. As i have said i have never had one job where I got a call back due to pipe size. No doubt I have been doing it wrong all these years and 10 double decker buses are going to pull up outside my house with all the customers complaining at once.lol
haha this made me laugh, i had a nightmare like this once. .. lol
