View the thread, titled "Low gas pressure" which is posted in Gas Engineers Forum on UK Plumbers Forums.
22 more than good enough pressure drop of 0.73 aprox
At 32kw 8m 12 elbows
Up the pipe work jay easily accessible part
Would of thought it would be fine but if manufacturer said needs bigger up it
Seems silly though when the simple calculation tells you that the 22 should be fine
Yep but are they going to refuse warrenty if somthing wrong later down the line. Saying aload of bumf about Pipework
It should sort it but I'm still not entirely convinced that it should be required
Totally agree Shaun it just seems daft when we are all using one type of calculation and then the manufacturer tells you you need to up size it. If there is a factor to take into account with their product then they should make you aware of this otherwise quite legitimately you are going to do your pipe sizing calculation and only find out when the thing is connected that it doesn't work. It hardly seems fair for them to refuse the warranty when you have actually done the due diligence of calculating the pipe sizes
Actually, as per the Viper book, I calculated the pipe size required to carry 3.75m3/h and its 28mm :/ it's because the pipework from the meter doesn't branch until it hits the boiler when it tees to the hob. I just hope that the section I up to 28mm is enough.
Didn't work! Got another 0.15 m3/h - now have to take up the floor to replace the rest of the run as the guy don't want it run externally..
Reply to the thread, titled "Low gas pressure" which is posted in Gas Engineers Forum on Plumbers Forums.
Thread starter
jaydebruyne
Joined
Location
London, UK
Heating Engineer (Has GSR)
Thread Information
Title
Low gas pressure
Prefix
N/A
Forum
Gas Engineers Forum
Start date
Last reply date
Thread Tags
jaydebruyne,
Last Plumber,
