View the thread, titled "Unvented Hot Water System" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
Rachael1278
Hi, I’ve purchased a new build property and had a few issues with the unvented hot water system. I’ve now asked the developer, builder and plumber for proof of G3 certificate of the plumbers but have been told they have no need to show me this. I’ve searched the gas safe register and it’s not showing on their profile, however this doesn’t tell me definitely that they do not hold the qualification.
Anybody know what I can do to check this? Building control who signed off the house are basically unhelpful/uninterested.
Yes it’s a requirement for them to prove it’s been installed safely also you should have a building control certificate saying it’s been installed and upto spec any pictures of the cylinder/ pipework and what’s the problems?
The certification side of things all a bit of a farcical nonsense in my opinion and experience so I wouldn't get too hung up on that. Building control won't know anything about it.
What are the issues?
Hi, tried replying previously but not sure it uploaded?
Initially the immersion heater was left on which covered up faults with mechanical valves. That’s now sorted but the cylinder appears not to be holding any heat. I had the boiler on constantly as advised by the plumber but when I turn it on to timed (2 hours in the morning and evening daily) after a couple of days I only have like warm water, even straight after the timed period.
I also can’t have the secondary loop turned on as this drains the stored hot water even quicker
It’s because of your secondary return pump top left gold pump I’m guessing the pipes arnt insulated well and there’s no check valve on it
Thank you 😊.
Should the pipes be insulated for the whole loop or just the exposed ones I can see?
Am I correct in thinking that this issue is something that all competent plumbers would spot and be aware of, and lack of knowledge from my plumber in this respect is giving me doubts on his competency for the safety of the whole set up.
The cylinder now doesn’t hold heat. Boiler timed for twice a day, 2 hours but only get Luke warm water. Cannot have the secondary loop on as this drains the hot water even quicker.
I’ve uploaded pics
Thank you for your reply 😊
Thank you 😊.
Apologies for bombarding you with questions.
Where should the return into the cylinder from the secondary loop be? Is it joined to the main cold feed as part of its loop?
Thank you 😊.
Both as it’s a secondary system
If you can try closing one of the valves on the bronze pump eg pair of pliers turn clockwise
And tbh yes as it’s part of the signing off process are all pipes insulated eg if you look in the back of the cylinder instructions should be a commissioning page
I’ve uploaded pics
There is a possible issue that needs ruling out. Is there a stop tap on the cold fill side of the cylinder? I cannot see from the photo's. It would normally be before that multi block (brass) on the back right hand side.
Hi, I will try this as soon as I’m back home. Sorry to sound silly but what will I be looking to happen once I close this valve?
The checklist says it’s insulated! I don’t think it will be possible for me to ever know if the full length has been insulated as it’s underneath concrete flooring in a void! Can I do anything about the checklist having false information?
Will stop any flow from the secondary / pump side incase it’s moving that way
The pipework isn’t insulated on show so I would contact your solicitor
Reply to the thread, titled "Unvented Hot Water System" which is posted in UK Plumbers Forums on Plumbers Forums.
Thread Information
Title
Prefix
N/A
Forum
UK Plumbers Forums
Start date
Last reply date
Unsolved
Rachael1278,
Last Plumber,
