Unvented Hot Water System
View the thread, titled "Unvented Hot Water System" which is posted in UK Plumbers Forums on UK Plumbers Forums.
R
Rachael1278
Hi, I’ve purchased a new build property and had a few issues with the unvented hot water system. I’ve now asked the developer, builder and plumber for proof of G3 certificate of the plumbers but have been told they have no need to show me this. I’ve searched the gas safe register and it’s not showing on their profile, however this doesn’t tell me definitely that they do not hold the qualification.
Anybody know what I can do to check this? Building control who signed off the house are basically unhelpful/uninterested.
Hope this helps
Normally fitted to bathrooms / taps the other end of the house / far away from the cylinder as you have to run the hot tap for a while to get hot water due to the distance and the cold water in the pipe as it’s unlagged/ gone cold etc
You haven't got the valve I wanted to see but never mind. Once you have closed the valve Shaun asked you to, close the one on the very top of the cylinder too. There should be no water from hot taps after an initial short run off.
Open them both again once you have found out whether it stops running or not.
Evening, the water stopped after the initial run off as you said.
Ah, I am silly aren’t I!! I will try this again now and let you know in the morning
Good morning,
So, the hot water was on from 6-7am, just tried hot water and it’s probably a little warmer but still not hot as it should be.
I did notice that the secondary return pipe where it enters the cylinder was hot to touch when brass valve under the pump was turned off but when I turn it back to open it instantly goes cold. No idea if this means anything.
Thank you.
Right now turn turning the lever valve off at the top of the cylinder eg the pipe leaving the centre top of the cylinder and the pump one keep that off aswell please
Correct but does the cylinder heat up / you have hotter water, if you do have hotter water that means water is flowing out of your cylinder all the time maybe
Also the red valve on the left wall just higher than the immersion is this open?
So am I to turn of the lever on the top of the cylinder, turn the boiler on, wait a while, turn the lever back to open and test the water temp from the tap?
Red valve to the left is open.
Thank you for your patience
Yes your testing if the cylinder will heat up at all when you re open the top lever valve after an hour and it gets instantly hot around 6” above the cylinder/ as high as you can feel there’s a problem
Ok, all turned to off and boiler set to constant. Pipes that are currently hot I’ve detailed on the attached picture. I will give it an hour and the open to lever, feel pipes again and run hot tap.
Red-hot
Orange - warm
Blue - cold
Red-hot
Orange - warm
Blue - cold
So, after an hour I turn the lever back on. Hot water draw off pipe got warmer (not red hot) to touched after a few minutes. No hot water taps have been turned on at this point.
The coil 1 pipe at the very bottom of the cylinder is now also very hot to touch and the cold feed pipe at the bottom is tepid, whereas before it was stone cold.
Right ok shut that red valve again and turn the hot water on eg heat up and leave it until it finishes eg fully heats up the cylinder you can tell this by moving the stat it’s on 60 ish now if it doesn’t click lower than this it’s fully heated
Ok, done that. The stat clicked when I turned it down at about the 45 marker, turned back to 60.
Will the ignition/flame light go off on the boiler when it’s fully hot?
Reply to the thread, titled "Unvented Hot Water System" which is posted in UK Plumbers Forums on Plumbers Forums.
Rachael1278,
Last Plumber,
