buckley plumb
been to this today intermittent f75 .it had this just over a year ago and I replaced the orange pressure switch with the new type.checked x2 green wire and got 2.16 volt dc pump not running and 2.24 volt dc with pump on . sods law boiler would not fault when there . called vaillant to see what voltage increase should be when pump runs - they said 0.5 volt dc min of 0.2 volt I was not getting anywhere near that 0.08volt dc yet boiler was working . the property was 3 storey and all rads go hot quick so pump seems ok .tech suggested I replace press sw / flexi pipe on the flow pipe and the pump - going back with new press sw as all the rads are old and I suspect the crap has blocked the press sw .
