DuckyUC
Hi again
I fitted a instant electric water heater to supply hot water for whole flat
but the hot water flow are quite low
So I am finding a pump that can:
1. pump only on when water flow
so no pump noise all the time and the pump have longer live
2. pump can tune how much water flow/pressure to increase
the water heater have a max 10bar Rated pressure
If the water flow too high the water heater wont able to heat up the water to require temperature
I find a pump call Salamander home boost on google
It only on when water flow but it design to maintain 12L/min all the time so I do worry that will give too high water flow and the water heater wont able to heat up the water to require temperature.
Any recommend for water pumps?
so the heater we said would not be good enough and have a good enough flow rate is........................... not good enough and does not have a good enough flow rate ?
:19:
increasing the flow will make your hot water cold.
the water heater have a max temp of 55C set by it thermostat, so I want to increase the water flow to a point until the water heater cant heat any more water
for now the hot water amount restricted by the low water flow, whatever how low the water flow the max temp is 55c so it is potential able to generate more hot water by increase the flow
Good idea,
I find [h=4]Grundfos UPA 15-90N[/h]Which is cheaper and
1. do have flow switch
2. able to turn the output
I find it cost £131 online will this be a good option?
The only bad thing is Salamander home boost able to fit on the water main but [h=4]fit Grundfos UPA 15-90N need consent from the water supply company (I guess they wont say no as long as the pump draw less than 12L/min water)[/h]
They will say no as it's not an approved product. Both of the pumps I listed will only turn on when the tap is opened. They are suitable because they have flow limiters built in. Unless you look at fitting break tanks there are only two pumps that are suitable at the moment.
Thanks mike, I think I will go for Salamander home boost+ restrictor solution.
If I get a contractor give me a solution without understand what happen they often provide some solution seem ok before they leave then find more problem after. As I do found a
a qualified plumber to fit the water heater already, dont want to waste the money again, the labor is like 2-4 times of the material itself.
If I open 3 post ask 3 exactly the same question then you are right. If I want get instant access to hot water how does those advise me to install a immersion help? Think about it, will you buy a car that take 2hours to charge before it run and the battery only last 40min? If everyone prefer a car can run anytime why not for the water heater?
This is a great example of how not to manage a project in your home.
Ask advice, ignore advice, buy unsuitable product with no thought to installation or long term operation, employ plumber/electrician to install unsuitable equipment, blame plumber/electrician for equipment not supplying sufficient hot water (as was advised on numerous occasions), look for pump to fix screw up that probably won't anyway.
I'm off in the shower now with ample hot water.
Reactions: 4 people
Would that be a shower fed with hot water from an un-vented storage cylinder SimonG ???? I bet it has a good flowrate as well & how much did you say it cost to supply & install was it £400 or did you go for the more expensive one at £600 !! L very much OL.
Reactions: 2 people
I used an un-vented storage cylinder before, hot water last 40min and take 1-2 hours to boil once hot water run out.
The point is get unlimited instant access of hot water, how your advise able to do so?
The wiring upgrade only one off cost, and in the future repair/replace the instant water heater + pump only take 30min.
The storage heater you recommend, not even able to drain the water in 30min and start any meaningful repair.
