Jan 13, 2024
25
Essex
DIY or Homeowner
Hello,
I am plumbing in a double basin sink based on the first pic that I mined from a Reddit thread. (happy to accept suggestions on if this is correct as well)
My waste pipe is 32mm and mounted in the floor. I will be mostly solvent welding
However when I look at the top of the p-trap, I have no idea what the name of the connector needed to attach the top of the p-trap with a section of pipe that will go into the tee.
I thought it might be a 32mm straight coupler, but it doesn't fit the top of the trap. I can only think it needs to be something like a threaded attachment to 32mm solvent pipe?
I've googled about every possible guess I can think of!
So here's my scenario now - if I attach the traps to the basin wastes, you can see that I won't have space for the AAV valve. This is the max the telescopic p-trap will extend to on the right.
Is it acceptable to extend a piece of pipe straight down from the wastes and mount the traps lower (I'd imagine taking them to level or slightly lower than the shelf in the middle, so I can have the AAV valve mounted at least 200mm above them.
Or should I angle the outfeeds from the traps with 135 degree bends downwards? this doesn't seem like a good idea.
Any advice? thanks.
hey @fowlerboi @Ben-gee this is how it turned out. Would have liked the AAV to have more height but I didn't want to drop the traps any more than I had already, and I couldn't source a 32mm cross tee (they only seem to be 40mm and 50mm). I did have 2 traps the same but thought it couldn't hurt to put the one with the small air valve on it as well
Don't know how legit it all is, but it doesn't leak and the sinks drain faster than any other sink in our house!
Thanks for your advice
Reactions: Jayp07
