Guest viewing is limited
What we all working on this week ?
View the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
king of pipes
Subscribed
I have a insurance job to try and rescue a poorly installed quad shower the customer wants to save the tiling if possible and has a few spare so fingers crossed it may work , the loss adjuster allowed em £1500 that will just about cover materials. Kop
Do you like the Walraven plastic pipe clips?
I've started using them they're expensive but very handy.
I think they are good, much better than talons and cheaper than munsens. I like that you get a but of adjustment when you place them and they clip in nicely. I get them from direct channel, they are online. What got me was I bought them from BSS first and they were Uponor branded and more than twice the price, was glad to find them on direct channel
It’s not my day today 😀
finished the boiler off and come to fire it up no oil flow either someone’s forgot to order some or someone’s nicked it which do you think the builders sticking to 😀
and then my testo decides to crap itself only just come back from service
Was asked by a local engineering workshop to connect a new bit of kit they had, said it need some electric and a water supply. Was told it should be quite quick to do, looks like it will be 2 days! Its an industrial parts washer for cleaning very small gears. Got to start the water supply tomorrow and install a settlement tank and drain major 😫
I like the lockshield valve on leg to exp vessel - great!
What's the mini shock arrester for?
so just goes to drain how are they handling the back flow risk?
so just goes to drain how are they handling the back flow risk ?
Do you mean for the CW supply or drainage? The machine empties into a settlement tank and then into a Drainmajor which will pump it up about 5m to a soil stack in the building. CW wise, I'm undecided what fluid risk it is at the moment. It doesn't actually hold any water as such, it just fills at a steady rate from the top of the drum and discharges out of the bottom through an open waste. Its not possible for it to over fill into the machine itself as the water just runs straight out of it. Id like it to be CAT 3, but it might be CAT 4
any cleaning chemicals or is it just rocks ?
Both, the drum
It uses aggregate and chemicals, but they don’t mix with the water before going into the mixing drum, they both have separate supply lines so I can’t see any risk of contamination. I’d say that there is less risk than you would get with say a dish washer or washing machine, I might just fit a double check valve. The other option is an RPZ valve but they are pricey and not so easy to get hold off.
Reply to the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on Plumbers Forums.
king of pipes,
Chuck,
