What we all working on this week ?
View the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on UK Plumbers Forums.
king of pipes
Subscribed
I have a insurance job to try and rescue a poorly installed quad shower the customer wants to save the tiling if possible and has a few spare so fingers crossed it may work , the loss adjuster allowed em £1500 that will just about cover materials. Kop
To frigging hot today so sacked off the bathroom job come 1 o'clock and fixed a Baxi duo tec for a mate .
Monday’s job oooo goody
Was the tray a 2 man job?
Yes mate me and the plasterer sorted it had to chop in the wall at one end, flexible tile adhesive to bed it in siliconed up before tiling bud
[automerge]1593204712[/automerge]
Love a tight fit 😂😂
You back up and running H ??
[automerge]1593205799[/automerge]
Update chaps after talking to Aqualisa technical , I have adjusted the processor control unit to HP eco mode from combi mode this reduces the flow by 2 litres a minute and removed the flow limiter it is not guaranteed to work faultlessly and can fluctuate slightly on temperature but a 2 litres a minute saving is worth trying also getting a grate made with 40 extra holes so should help. Kop
Laser cut drain grate
First ever main heat exchanger replacement for a Vaillant Ecotec today - 3 & 1/2 hours, including adding inhibitor, and dropping off a part to a mate.
Get some plasterboard in the garage and give it a go. Had to self teach myself after being let down all the time. I'm definitely slower but can get a good finish.
Yes I have been thinking this. Did you use a practice plaster mix (lime and sand) on the plasterboard. Notnsure if it would stick to that or not?
Just use multi finish, think of it as an investment in your future happiness, not having to try and grab a plasterer at short notice when all the walls fall apart as some as you drop your tool bag a bit heavily on day one!
I see. Just keeping adding layer after layer until I can get a decent finish. Nice idea. Thanks
No that’s not what I meant mutley.
multi- finish is the product name.
The usual method is to apply it in two layers, the second being applied whilst the first is still live - it’s getting the timing right that is the trick.
Same again in terms of timing for your final trowel up; too soon it all moves around too much and goes wavy; too late and .... well it’s too late!
Same again in terms of timing for your final trowel up; too soon it all moves around too much and goes wavy; too late and .. we’ll it’s too late!
Ah I see Ben-Gee. But, you could keep adding coats on top until you get it to a level you are happy with hey?
Reply to the thread, titled "What we all working on this week ?" which is posted in UK Plumbers Forums on Plumbers Forums.
king of pipes,
Chuck,
