Allo, I installed a Worcester 30 si today and was doing the commisioning. I put it into service mode(press and hold service button for more than 10 secs) boiler goes into over drive for 15mins. Checked the working pressure at the meter 19mbar then checked the inlet working pressure at the boiler inlet 18mbar. This is all good? The thing that is confusing me is that in the MI it has a drawing, (Figure 70 on page 33) its a diagram of a meter then the boiler then the gas valve. The meter is 19-23 the boiler is 18-22 and the gas valve is 16.5-20.5. I understand that worcester say they will allow a 2.5mbar pressure drop from the meter to the gas valve but when im testing the burner pressure on the gas valve im getting -4mbar. what is that about????
Also when im gas rating the boiler it should be 3.24m3/h but im getting 2.94m3/h
