Oct 8, 2017
Filey
General Plumber
So I was recently doing a gas test and service on a caravan with Not go GB24 S2, the boiler has giving off a gas rate of 0.87m3/h. I checked the inlet pressure of about 39mbar, the meter it was been fed from was brand new. The pipework was all fine. I am just wondering what should I do in this situation if I couldn't find a fault the FGA was also fine
No gas advice given on the open forum PM @Harvest Fields @ShaunCorbs or @Riley with your gas safe details and we’ll get you access to the gas safe forum. Also we need a little involvement from you. Post a few more comments, introduce yourself etc. We just want to know that you’re not just using us for our minds
If we are talking about output readings and gas rates. Should this be moved to a area that isn’t open?
The difference in calorific value between natural gas and LPG are huge. When doing calculations we are told to use 38.7 MJ/m3 for natural gas as an average but I cant find an average for LPG. Data says its between 90 and 95 so average is 92.5. op said he got a reading of 0.87 m3/hr so using these numbers if we do the calculation using the natural gas formula we get 0.87 x 38.7 / 3.6 = 9.35kw. if we do the calculation using the lpg formula we get 0.87 x 92.5 / 3.6 = 22.4kw which is still a bit low but when dealing with caravans keeping the boiler on high rate for 2 mins isn’t always easy. Dhw flow rate and small heating load can mean boiler wont stay on high rate for that long. Yes I am GSR just don’t have the badge
  • Agree
Reactions: ShaunCorbs
As Shaun said its unsual to have a meter on a caravan site unless it's bulk storage supplied directly by the site.
What is the question? Have you just installed the morco? Was it new?
There is some by me in Staffordshire where the whole site is ran on G20 mate. (75 static vans)
