T
tonyacktar
Worcester 9.24 rsf no central heating.
I know its an ancient boiler and yes it will be replaced soon (with a baxi duo tec)
But just for knowledge sake...The DHW works fine but central heating does not work at all. All obvious things have been checked like c/h thermistor, programmer, air flow switch, pump and fan and they are all fine.
I assume its the pcb...but after looking at the wiring diagram have a niggle about the flow switches on the diverter valve..could it be that the switch is not flicking back to CH.
Could this be a possibility and is there any way of checking.
Thanks in advance.
Come on mate.
29 posts and you don't know the forum rules on Advice in open forums about gas appliances?
You have enough posts to join the gas safe registered part of this great forum.
Send one of the mods a pm with your gas safe number and your in after a few checks.
If your not gas safe, stop messing :45:
