Worcester Greenstar 24Ri LPG boiler hot water ok but no central heating
View the thread, titled "Worcester Greenstar 24Ri LPG boiler hot water ok but no central heating" which is posted in Boiler Advice Forum on UK Plumbers Forums.
digbyl123
Hello Folks , first time on here so be gentle !
I have a conventional vented heating system with hot water cylinder in the airing cupboard . The whole system is 4 years old and runs on LPG . I have a salus pump , 3 port valve and control pack . The pump was replaced a year ago as although it seemed to work was not actually circulating any water ?
Everything was fine until 3 weeks ago , the central heating stopped working . The Hot water is working perfectly on the timer and the boiler comes on and goes off as it should . If I just pust the central heating on , or have it on timer the boiler seems to initialise but the green ignition light does not come on and it shuts down . The blue light does not flash to indicate a fault code . The room thermostate appears to operate ok and I changed the head on the 3 port valve as I have a spare . I have tested the 2 fuses on the PCB in the boiler and these are both OK
It seems the boiler isn't triggering the 3 port valve to go to port B ( C.H.) position
Could this be a fault with the PCB in the boiler ? Can you test the wiring to the 3 port valve from the boiler ?
Any help would be gratefully received , Thanks , Digs
This plumbing forum will not provide advice to anybody with regards to boiler repairs or any other form of gas plumbing without you first providing us with your Gas Safe Registration number in a thread - for very obvious reasons. If you're not qualified to touch gas, you should stay well clear of trying to!
Reply to the thread, titled "Worcester Greenstar 24Ri LPG boiler hot water ok but no central heating" which is posted in Boiler Advice Forum on Plumbers Forums.
digbyl123,
Rickster123,
