Working pressure effecting combustion.
View the thread, titled "Working pressure effecting combustion." which is posted in Gaining Plumbing Experience on UK Plumbers Forums.
I agree 1 can lead to the other however until pipework is sorted and you can confirm that was the low pressure issue in this instance, I’d say they should be classed as separate, what hpns if you advise that changing the pipework will sort the issue and it doesn’t
I don't know why it wouldn't, but they're not compounding issues, one doesn't make the other worse so for me it wouldn't change how I'd class the fault.
Undersized pipework and low pressure at the meter - that compounds
Poor combustion and inadequate flue terminal clearance - that compounds
I don't know why I'm arguing the Point tho as I'd AR it anyway 🙂
exactly my point, it’s his job and if he doesn’t separate them and changing the pipe doesn’t solve it, he will be left with the extra expense
I don't really understand gassafe their quite happy to let you make your own mind up but in the one time in 10years I got inspected the fella got really upset when I didn't get out the stopwatch for a drop test and said I'll time it if its dropped after I put my tools away.
I got the timer out 🙄
There still there just note down / advise but don’t act on which is what was done before but still there
Only saying what the guys leading the reassessment taught me and I’d rather use it than not
A regulation and a procedure. I'm quite happy to use NCS terminology and in my bubble I'm the law, but I'll consider the regulations while I'm putting on my spurs and drinking at the sloon😀
I wonder how much credit a court room judge or a solicitor would give to your ‘bubble’. Up to you though 🙂
I don’t disagree with the sentiment you still have to advise customers. Call it advisory NC NCS whatever you still have to do it
Reply to the thread, titled "Working pressure effecting combustion." which is posted in Gaining Plumbing Experience on Plumbers Forums.
Knappers,
Knappers,
