Worst boiler to work on competition
View the thread, titled "Worst boiler to work on competition" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Nostrum
As above, whats the worse part/boiler you've had to work on and why? (no detail into gas safety as it's in the wrong forum!)
personally for me, after today i'm voting Worcester CDI expansion vessel. Wasn't much left in it once I got the old one out, fan, heat ex, plate hex, pump, APS etc all removed.... nightmare! Normally fit an external in, but couldn't on this one.
The 3 Buderus GB162's in a galvanising factory over here. They're only 3 years old but look 103, each one has been completely rebuilt at least once, 2 heat exchangers, all the connection boards, two wiring harnesses, the combustion fans fail about every other month, one flue has been replaced and so on. My heart sinks every time I'm asked to go to silverwood.
And why are they so much hard work? Because they supply hot water for the acid vats and are in a highly corrosive atmosphere. Tools develop a fine layer of corrosion within an hour. I hate the place because it actually makes you doubt yourself.
And I normally love the GB162! Just a case of the wrong boiler for the environment.
Ferroli Modena HE Just look at them and they start to leak from everywhere.
Or any boiler where they dont supply all the O rings that you need so you try to get them all and forget 1 and guess where it will leak from.
worc greenstar junior. got sent out by boss to replace hw hex and instructions said just remove two screws and replace hex. on previous page they happen to hide the fact that you have to remove the whole water section first! luck had it i was installing a scale inhibitor and after removing the cold main wiggled the biggest hw hex in the world out and replaced. a hex the size of a bath and it still gets blocked up!!
potterton puma for installation........ about 20% would fail to run and after a week about 50% had a fault. normally one of the pcbs, gas valve or pump failure. ended up with a van full of free spare parts to save time waiting for an engineer.
Without a doubt anything French!!!
The saunia duval SD620 beats the CDi hands down in my books. Rubber hoses that melted to the copper, telescopic fittings that leaked if you stared at them for to long! And even the thermocouple was a mare to replace!! Thankfully they're all just about gone!
The Myson Midas was a pain too!!
anyone installed grant wall hung oil system boiler. great design with no thought at all to the fact you need to connect pipes to it ! what a joke! pity because the floor standers are pretty good.
can i just ask what the difference is with the gas safe installer section on the forum? wondering if i need some of this in my life?
As said only gas safe registered engineers allowed in ... you can get a lot more technical and discuss safety related stuff that's a bit dodgy to discuss in an open forum!
The saunia duval SD623 beats the CDi hands down in my books. Rubber hoses that melted to the copper, telescopic fittings that leaked if you stared at them for to long! And even the thermocouple was a mare to replace!! Thankfully they're all just about gone!
Diamond are they the old sauniers that had a flap in the flue as an APS?
AWheating I am still repairing pumas now! There are a few estates around here that were fitted up with them, and a few still remain.
Agree with millsy on the O ring subject, why is it some manufacturers give you 90% of the O rings you need to change a part how they suggest, and throw a few others in that are useless along the way? Have to do a diverter on another 28CDI next week, only needs a diaphragm but you have to remove the whole valve completely to get to the diaphragm so just as well chuck a new one in and get the washers/O rings with it as well. I think it almost works out cheaper as well.
You say anything french, personally I love the chaffoteaux britony combis I know them inside out and they are very easy to work on. Just don't touch anything you don't have to!
I'm trying to remember that boiler I'm pretty sure they had a diaphragm APS? The y had a rubber boot on the back for connecting the flue I remember and the changeover sliding black lever on the front to change from hot water only to water and heating!!!
the cdi it will still leak everywhere
strange i always loved saunier 620s found them easy to work on rebuild one in half hour easy provided they hadnt been left leaking for years when all the screws would be rusted up the one i hated most was the early potterton combi i think it was the lynx came in a nice shade of beige and had to be the most complicated combi ever with hot wire fan detection
almost as bad was the ideal (also beige )think it was the midas which was the size of a cooker hanging on the wall had several pcbs and relays in a drawer at the bottom
worst pcb to change had to be the ELM LEBLANC 27 wires in a casing half the size it needed to be with several swiches that fell out when you tried to get it back together
Actually the worst boiler to repair has been the same for the last 30 years its the one in your inlaws place that you wont get paid to do and invarably is the one you manage to short out the pcb whilst doing something minor
one boiler that suffers really bad faults is the Baxi Bahama SIT version,not everythings the flow switch sometimes its 90% of the rest of the boiler
and glowsheds past and present are also mares,and that micky mouse one we had a few years ago gem combi i think
always thought the worc cdi hw hex was a stuipid design. how ever well you drain the boiler when you pop off the hex (which is easy enough) you'll get a nice splash all over the pcb! dont worry the rubbish plastic cover will save us! stupid worc's.
is that the realy early condenser that had the ally hex?
no it was baxis stab at its first combi after dabbling with the genesis it was a SE boiler and a disaster from the word go the SIT control version would melt the boiler if it ran out of water it was so bad baxi had to buy ocean and its 240/280 combi and turn it into the 105
Remember the short lived Ideal minimiser? 😀 Boy they were shocking!!!
is that the one where you would attach a hose to the bottom and blow against the aps, always thought that cant be a great idea!
there were some realy rough combis made by english companies in the late eighties nineties the reason was the established english companies didnt forsee how fast the combis took over the market
in there rush to compete they made some awfull boilers then once the parts to make a combi became standised we had a spell where a new company would pop up each week it seemed, gems, euro combis, savios etc most fell by the wayside i think savio became biasi
i went on a baxi course years ago with the old man,bermudas were the daddy,combis were a weird new fangled idea,i was just a kid and fancied the bird at reception,LOL we were told they would never take off:24::smilielol5:but as we know combis did baxi was losing market share,the genesis basically a chaff in disguise came first ,then they rushed out the Bahama disaster
Changed a Worcester cdi BF diverter over yesterday!! I've done a few but yesterday's was a nightmare! Remember the first one I ever done I isolated flow and return valves turned them back on and they leaked everywhere learnt that the hard way.
Yesterday changed all the o rings over reassembled and the pig still decided to leak from the cold water inlet! Had to strip the whole thing back out again, soul destroying! eventually got it done, bit of fernox lsx gives you peace of mind 🙂
I'm only in my early twenties so won't have come across much of the older stuff as the experienced guys!
During my apprenticeship when on the servicing the lads used to hate hitting a black ash or an opus fire/bbu, always remember they were a big lump that hogged the dog hair haha.
My first is the Alpha Ocean Style FF, if you went at one O-ring you would have to replace all the O-rings, changing the O-rings could take 30 minutes or 4+ hours depending how lucky you were, it would get so that your tears matched the drips from the O-rings, my second would be the servowarm boiler with the rad on the front because swinging the rad out always felt wrong.
I think I serviced one of those yesterday. Is that the boiler with the silly little copper tube connected to the fan and you have to remove it along with the fan to clean the condense?
Can't believe there's one still running 🙂
Yep it had a tube attached to the fan and the burners kept rotting, fan seal kept leaking, condensate was a mess and the ignitors too ... they slung the burner under the base of the hex... !!
For overall bad design, faults, fault diagnosis and being installer unfriendly, I think the Gledhill Gulfstream desrves a mention. Have only worked on the one; four years running, new fault/faults each year.
and the gledhill boilermate should win some sort of award for being useless aS WELL
620 had the paddle type air switch and the later 623 had a normal diaphram type actually the paddle one was pretty near bullet proof
Reply to the thread, titled "Worst boiler to work on competition" which is posted in Boiler Advice Forum on Plumbers Forums.
Nostrum,
wattsie1987,
