View the thread, titled "Worst boiler to work on competition" which is posted in Boiler Advice Forum on UK Plumbers Forums.
Why? What problems have you had?
I hate the plastic case. I hate the stupid display that confuses every customer. Hate the way that when you unpack it and remove the plastic plugs half a pint of jet black water comes out. Always half to free the pump up on start up. Nuts are a nightmare to tighten. Condense fitting is in a stupid spot that always looks pony no matter how you pipe it. So all in all, not keen!
Diamond are they the old sauniers that had a flap in the flue as an APS?
AWheating I am still repairing pumas now! There are a few estates around here that were fitted up with them, and a few still remain.
Agree with millsy on the O ring subject, why is it some manufacturers give you 90% of the O rings you need to change a part how they suggest, and throw a few others in that are useless along the way? Have to do a diverter on another 28CDI next week, only needs a diaphragm but you have to remove the whole valve completely to get to the diaphragm so just as well chuck a new one in and get the washers/O rings with it as well. I think it almost works out cheaper as well.
You say anything french, personally I love the chaffoteaux britony combis I know them inside out and they are very easy to work on. Just don't touch anything you don't have to!
I always do diaphrams without removing the diverter valves on CDI's, the screw right at the back to take the head off is really alkward to get to but I use a small ratchett, still a nasty job but prefer it to removing whole thing.
Easiest - Open flue thorn M42 🙂 - More modern I've worked on a good few Baxi's and find them relatively easy to get around! The GloWorms are a mare!!!
went to look at a pig of a thing earlier was just told by the custy its a baxi combi,it was a baxi genesis,sorry mate not touching that
Yes the Genisis was baxi's hybrid transition to the combi market! A monstrosity! The guts of a combi lumped on top of an apollo 80 If my memory serves me well?
its a chaff in disguise plastic everywhere
Plastic ... hmmmm! So then it's the one with the guts slung underneath? Another horrible piece of kit I wonder what boiler it was with the gutts above? I'm sure it was a baxi???
Yeh wall mounted, as said it had the old apollo 80 BF bellow it and an add on pump, diverter and weird little cylinder thing blue i think it was heat-ex 🙂
i think i know what your on about it was a right bitsa if its the same heap,nasty shed of a thing
Chaff Britony , look after loads of these still, I like um! Not a great boiler but everything is simples and relatively cheap to fix... Wouldn't have one in my house though!The later SE isn't bad though!Neither are any more plasticy than a green star junior!
yes but i dont like greenstars either😀 mind baxis 133 he is far,far worst
Reply to the thread, titled "Worst boiler to work on competition" which is posted in Boiler Advice Forum on Plumbers Forums.
Thread starter
Nostrum
Joined
Location
Devon
Thread Information
Title
Prefix
N/A
Forum
Boiler Advice Forum
Start date
Last reply date
Thread Tags
Nostrum,
wattsie1987,
