Discuss Advanced Appliances thermal store in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sheff paul
Fitting one of thease with a mate,cannot see if you need a pressure reducing valve on incoming main,manufactuer was closed today,anybody any experience of thease,this one is going to be linked up to a log buning stove,any advice would be good
Reply to Advanced Appliances thermal store in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each apartment for domestic hot water varies greatly in timing and volume. Thus the oil boiler is required to work for long periods which is uneconomical...
Hi - I have a Telford's Tristar Thermal store with a Caleffi 533..h PRV set to 3 bar. The PRV doesn't appear to be drop tight, so static rises from 3 bar to 5.6 bar when no flow. When I had the thermostat replaced on the cylinder recently the plumber doing the job suggested I should...
I'm looking for help with an open vented central heating system that is pumping over. We have a thermal store that has two heat sources - gas central heating, and a wood burner - both feeds are pumped with a Wilo Smart A 25/4-130 circulation (one pump per feed). When the wood burner kicks in...
According to the manufacturer's information OV PULSAcoil thermal stores are primarily designed for use with on/off peak electricity but also have two open pipe spigots (NO internal coil) for flow and return from an additional heat source e.g. a heat only boiler. The 180 store comes with a...
Hi sorry bit of an odd query here. With the increases in energy costs now and in the future we are trying to find any way to reduce our exposure (retired couple on fixed incomes). We are fortunate enough to have bought solar panels at the beginning of the year but as we head towards winter the...
1K
