Discuss Concertina toilet pan connector/soil stack leaking at joint. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Did some repairs to upstairs cistern (using a lot of advice here - thanks). Decided to fit a new concertina toilet pan connector while everything was accessible. What we bought & how it was fitted is identical to existing.
Lubricated with fairy liquid the concertina slid extremely easily into the horizontal soil stack pipe (the bit with the rubber seal inside), BUT, though it does not appear to have been leaking before, it is now!
Just the tiniest 'drip' but obviously can't be left. The 'seal' doesn't seem to be tight enough & it can't go in any further. I've been advised that what should be pushed into the stack end first, should be a plain section of pipe only about 4" long, & it will be secure in there by the rubber seal already inside the soil stack.
Than the concertina pan connector will push into the other end of this piece of pipe. I don't quite understand, is this correct? An ordinary piece of pipe, with no seals either end of itself, will have the concertina merely pushed in on one end, & then itself push into the soil stack?
Not sure if this is making sense, so hope someone can advise.
Did this, exactly as before! 'Fix' sounded too simple, just a plain short section of pipe, no seals or anything either end of it, only what us already fixed inside the stack & on the concertina connector. (The photo is slightly misleading, that kitchen roll isn't actually as wet as it looks - shadows.)
So is there a short piece already in the section between pan connector and soil branch? If so the rubber at the branch could be damaged/perished. If not then you will need a small section of pipe, otherwise there will be too much movement, hence your small drip.
You did leave the fin/ rubber seal on the pan connector ?
Fix is indeed that simple.
The difference being the pan connector will be fitting INSIDE a 110 diameter pipe, whereas now you have it in a socket.
It is now in ~110 space - fins not sealing.
It will be in ~104 space -fins seal, no leak. (as designed to do).
By the way, I would plumb it in rigid pipework anyway if I were doing it - flexis are rubbish and should not be sold in my opinion.
No short piece between the pan connector & the soil branch. That's sounding like it's the problem.
Yes, did leave fins (good word to describe those) on the pan connector. Seems like advice to put a section of plain 4" pipe, pushing 1 end into soil stack & pushing pan concertina connector into the other end (the fins of the concertina forming the seal).
All been a big learning curve, help here is much appreciated (personally, I'd rather have employed a plumber - but none were interested!).
Thank you all very much. Explanation very clear, no wonder it slid into the soil pipe so easily (had not been so easy a week or so ago when doing the same task in a different toilet - which was 104 going into 104 - & took a lot more 'welly' & fairy liquid). Job done & doesn't seem to be leaking. Cheers.
Sorry to burst your bubble but there are so many reasons why flexi soil connectors are not fit for purpose. They are an easy fix which no professional would ever use. Thin walled, un sanitary just to begin, centralheatking
Reply to Concertina toilet pan connector/soil stack leaking at joint. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I had a plumber in to replace my old pan connector as it was leaking due to the wax deteriorating. Now when this toilet clogs up (which is a...
Hi all, We've got a toilet that's been leaking due to a faulty seal with the pan connector. We've had a plumber in to replace the pan connector...
Hi! Totally inexperienced DIY newbie so bear with me for descriptions! Pictures hopefully help. I’m trying to remove an unused downstairs toilet...
Hi guys, I’ve got a close coupled toilet wher the waste come out of the back of the toilet then it’s a 90 degree bend to the right where it goes...
Hi, fitting a back to wall toilet in a small cloakroom. The soil pipe is a vertical clay pipe about 20cm from the wall and so I will have to build...
Deleted member 120897
